01-14-2015, 09:04 PM | #41 |
RCC Addict Join Date: Jul 2009 Location: AT THE DRAGON'S LAIR
| Re: C.I. 4340 steel; 5mm - Axial Transmission Outputs
Any updates, no pressure! Thank you! |
07-03-2017, 01:58 PM | #42 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Re: C.I. 4340 steel; 5mm - Axial Transmission Outputs Crawler Innovations is pleased to offer our 4340 steel, Lightened & Extended front & standard length rear transmission outputs for Axial transmissions. This is a permanent fix to weak outputs. This design incorporates a 5mm round with cross pin hole. These outputs work with any manufacturers drive shafts that are 5mm. These outputs are cut from 4340 "Chrome Moly" steel. They have been lightened by gun drilling the back side of the output, down the center. The 3 piece tab arrangement also reduces weight. These are the lightest and strongest SCX outputs available. The reason the front shaft is longer is to move the drive shaft away from the spur gear. This added clearance allows for the use of larger spur gears in order to gear lower for increased torque & smoother start up. For brushless motors it is critical to ensure a smooth start up with no cogging. They are sold in a set which is one long front and one short rear for $54.95 CWR-5013 |
C.I. 4340 steel; 5mm - Axial Transmission Outputs - Similar Threads | ||||
C.I. - 4340 steel - Axial transmission outputs for Traxxas Maxx driveshafts | Nova's Ark | Axial AX-10 Scorpion | 5 | 02-23-2011 08:19 AM |
C.I. - 4340 steel - Axial transmission outputs for Traxxas Maxx driveshafts | Nova's Ark | Axial SCX-10 | 14 | 02-20-2011 08:43 PM |
