Go Back   RCCrawler.com Bulletin Board > Vendors > Dinky RC
Like Tree8Likes
  • 6 Post By muddauber7
  • 2 Post By muddauber7
Thread: Dinky R/C's Tandem Trailer Kit
Old 12-22-2012, 11:54 AM   #1
DINKY R/C
muddauber7's Avatar
Default Dinky R/C's Tandem Trailer Kit
Our newest addition to our Trailer line-up, is sure to be a Big Hit at your next Scale GTG!
Specifically designed to fit the most common sized scale trucks on the market today.
Shown below, Locked & Loaded for the trip, is the new Axial JK Rubicon (Not Included)
to help show a size comparison.
Designed from the ground up to give you a realistic trailer towing experience,
without the high cost of investing in a custom built unit
or the complication of building one yourself!
Includes the Foot based hand crank stand, with a Stinger tipped handle!
Making it great for use as part of your Display as well!
Weighing in at just under 3lbs.,
it's light enough to keep from feeling like your towing a boat anchor!
Average loaded weight of 8-10lbs., pending on the weight of your particular rig.
Loading Ramps are specifically designed to stow away under the main deck area.
Tucking away cleanly, along the rear of the trailers tailgate area.
Also note the provisions for oval light buckets,
sized specifically for the all too common Axial light buckets.
You can easily gain access to the loading ramps
by reaching underneath the rear of the trailer.
Then spin them around, latching them into the tailgate area
to secure them for loading & unloading your favorite rig!
Outer rails are machined from 3/16" ABS
Deck surface and all other components are made from 1/8" ABS
Black ABS is textured on one side, and can be flipped either way, for you own unique look.
Manufactured as a Kit, with ease of assembly in mind.
The Tandem Trailer is made from ABS plastic.
And simply glues together with common Super Glue,
or ABS pipe glue.
Parts needed to complete this trailer listed below.
Alot of you may already have them in your spare parts bin,
or know someone who does.
Helping provide for an economical trailer project!
Deck Dimensions:
22.25" (56.5cm) Long x 10.5" (26.5cm) Wide x 2" (5cm) Tall
Overall Dimensions w/Tires mounted:
29.5" (73cm) Long x 14" (36cm) Wide x 3.5" (9cm) Tall
Kit does not include Wheels or Tires.
Recommended tire size of 3.5"- 4.25"
(Tires shown are from a Tamiya High-Lift)
Ball Stud and Ball end are NOT included.
All other mounting hardware needed to complete trailer IS included.
$110 + Shipping!
Order yours today, at DinkyRC.com
muddauber7 is offline   Reply With Quote
Old 12-22-2012, 01:10 PM   #2
We're G6'n & you know it!
DISTURBIN' tha PEACE's Avatar
Default Re: Dinky R/C's Tandem Trailer Kit
I really like this. Maybe after this Xmas madness.
DISTURBIN' tha PEACE is offline   Reply With Quote
Old 12-22-2012, 05:17 PM   #3
that's a great price for such a nice trailer
701 Technique is offline   Reply With Quote
Old 12-22-2012, 07:11 PM   #4
jonboyauto's Avatar
That's impressive. On the wish list for sure.
jonboyauto is offline   Reply With Quote
Old 12-23-2012, 10:26 AM   #5
Scale 4X4 Alliance
Pointman's Avatar
Nice! I really like it, but is there any way to get some fenders added to it?
Pointman is offline   Reply With Quote
Old 12-23-2012, 05:11 PM   #6
Scale builder
Looking great, I like the style of the deck. It also looks like it will be a nice piece to modify if you wanted... I think you guys hit a home run with the trailer and the pricing...
--Dan
sickcivic95 is offline   Reply With Quote
Old 12-24-2012, 09:07 AM   #7
- Bison Customs -
BC Racing's Avatar
There it is...glad its offically released!
Great work Matt!
Originally Posted by Pointman View Post
...but is there any way to get some fenders added to it?
They be coming!
--Dan
Modding it to suit your style is what its all about.
Keep an eye out for the "accessory line" of add on's! Coming soon to www.dinkyrc.com
BC Racing is offline   Reply With Quote
Old 12-26-2012, 02:23 PM   #8
Very impressive. I can't believe the quality and designs of all the items you guys make! I wish I could buy one of everything on your website! Then I'd be set!
TrxSlash5 is offline   Reply With Quote
Old 01-04-2013, 04:19 AM   #9
Very nice. Gonna pick one up for my son in a few weeks the price is a big selling point. Thanks for the great products.
elijah is offline   Reply With Quote
Old 01-04-2013, 07:16 AM   #10
Nice!
The Juice is offline   Reply With Quote
Old 01-11-2013, 10:31 PM   #11
Metal shaper
CarterFab's Avatar
Mine is almost complete.
Really cool kit and well executed. I added a Tractor Supply toolbox, and a Proline winch. If you do the tool box mod as I did, make sure and bolt in the bottom and also through the back of the tool box through the forward trailer frame rail. The top plate that I cut gives the tongue it's strength and must be compensated for after cutting. Trailer is loads lighter than a metal trailer I recently did some work on for Crawler InNovations and I don't believe it was this large.
I went with the stamped steel bead lock wheels due to the force that is put on the tires during tight turns and especially when it is loaded. Used the 1.55 Desert King tires from RC4wd as I wanted a small trailer style tire.
Will be adding a few more special CFM touches and some of the Dinky Trailer accessories as they become available. Now I just need a hitch for my sons rig to pull this bad boy.
CarterFab is offline   Reply With Quote
Old 01-12-2013, 01:13 PM   #12
DINKY R/C
muddauber7's Avatar
Lookin' Good Clay!
Nice choice of wheels and tires!
Old 01-16-2013, 09:01 PM   #13
Metal shaper
CarterFab's Avatar
Installed the Dinky Hitch today on my sons rig to get the trailer moving. Still have lighting and few more tricks up my sleeve to make this trailer really stand out. I'm having as much fun building on it as I'm the scalers, and my wife just rolls her eyes as I'm discussing how my son and I will drive it out and I'll unload the buggy and go crawling.
Old 02-26-2013, 05:01 PM   #14
Was wondering what the extras accessories for this trailer are and when they will be available.
Cheers jarrod
rustykaos is online now   Reply With Quote
Old 03-03-2013, 09:43 PM   #15
I saw what CarterFab did to his, but is there other way to widen the deck of trailer to fit a SC truck or buggy?
KauseKaos is offline   Reply With Quote
Old 03-06-2013, 06:43 AM   #16
DINKY R/C
muddauber7's Avatar
Cheers jarrod
Hoping to be releasing parts and accessories thru-out the next month or so.
He did a mighty fine job widening his, which was that much simpler due to it being made from plastic.
Trying to provide an inexpensive basic platform to build from, so making changes to it are that much easier for folks to accomplish, with minimal tools.
Pending on interest, we may look into making a smaller, and a larger version of this model, to help accommodate a wider variety of vehicles.
KauseKaos and rustykaos like this.
Old 03-06-2013, 09:31 AM   #17
I'll be in for a wider one
Old 03-06-2013, 02:47 PM   #18
Thats awesome to hear. Just waiting on my tandem to arrive.
Old 03-13-2013, 01:32 PM   #19
Originally Posted by muddauber7 View Post
Hoping to be releasing parts and accessories thru-out the next month or so....
Any word on the larger version. My Jeep was just delivered today and after I build it I wanna get a trailer.
Old 05-06-2013, 04:19 AM   #20
Yea, this is going to look sweat behind my crewcab silverado dually
evilozz is offline   Reply With Quote
Dinky R/C's Tandem Trailer Kit - Similar Threads
Dinky R/C Trailer Test ray2286 Scale Videos! 1 08-28-2012 05:33 PM
Looking for tandem axle cargo trailer Agama Colorado 0 11-07-2011 10:09 AM
gooseneck tandem trailer Double J Chit Chat 39 05-01-2006 11:55 AM
You may edit your posts
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
