![]() | #21 |
Rock Crawler ![]() Join Date: Aug 2005 Location: Illinois
The only way it is possible for one wheel to spin and not the other is if something is broke. Is there any kind of clicking? Is the dogbone popping out on the side thats not turning? A reviewer had an issue where he had to put an o-ring in the outer cup to keep the dogbone from moving back and forth in the joints. We are working with someone for optional motors. Hopefully soon. If you find you have broken part let me know. J |
![]() | #22 |
I wanna be Dave ![]() Join Date: Dec 2005 Location: Tax Nation
yup, I sure did hear a clicking... dogbone issues were my first thought when I looked at the parts diagrahm I just want to add, this is Duratrax first attempt at a crawler and a first release, lets not beat up on them too much yet, Im sure there are some machining issues that need worked out. I think with some CVD's and a straight axle adapter these axles would make a great low budget version of the berg Last edited by jetboat; 08-04-2008 at 01:13 PM. |
![]() | #23 |
problem #1 found the problem with the front axle is the dogbone coming out of the cup... I see 2 possible solutions: 1 Someone needs to make some CVD's 2 Use a spacer of some sort in the hub (O ring or spring) Honestly this is the first time I have pulled apart an axle from anything that runs dogbones and it didnt have a spring in it that is ment to keep the bone pushed in. You cant see it in the picture very well but it did chew up the cup a little ![]() Tons of screws to get the axle apart and it doesnt have an adjustable motor mount!!!!!! ![]() Inside shot of the axles (Im sure someone will ask for it) ![]() Its not up and running yet, the #35 o-rings I had on hand were too big so Ill stop tomorrow for some new smaller ones. Also I went ahead and pulled the rear servo off and am trying to figure out a good lockout. Rear steer is a fun novalty but its pointless on something this short. CVD's , steel gears and a better motor and I can see this truck being great for a 1.9" class. |
![]() | #24 |
Pebble Pounder Join Date: Jul 2008 Location: Toronto
![]() | #25 |
| ![]() http://www3.towerhobbies.com/cgi-bin...?&I=LXVFK0&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXVFJ9&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXVFK1&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXVFJ1&P=7 Do you have any o-rings out of an old pair of shocks? That should work or cut a small piece of fuel tubing. |
![]() | #26 |
Forgot to mention we also have a rear steer lockout coming. J |
![]() | #27 |
Rock Crawler Join Date: Jul 2007 Location: Rectalville
Wow... after seeing it in action, I'm suddenly less happy about winning one... oh, well, once I figure out how to put some 540 motors on it we'll be in business!
![]() | #28 |
yes...hpi bug Body...Thanks Jdawg...hadnt seen those... Now I run for cover, the TV just said a tornado is coming this way....fun ![]() |
![]() | #29 |
Rock Crawler ![]() Join Date: Apr 2008 Location: Wrightsville, PA
![]() | #30 |
RCC Addict Join Date: Jun 2004 Location: ORegon
well it looks decent width for 2.2 also. is the width comparable to a tlt? it looks like it could be. Well out of the box it isn't that impressive but I can't see anything that can't be fixed, so lots of room for improvement. I'll give duratrax a hand for just trying to make something and it really looks like it has potential. I think the only thing I can see that can't be fixed is the axles look a little boxy (at least can't be fixed without aftermarket parts. which would probably be aluminum and I wouldn't want aluminum for axles if I can avoid it). so some things to improve on but still thumbsup duratrax. where is traxxas? first hobby level rc was a stampede and i have loved traxxas ever since. They will pretty much be the last to jump on the wagon. I can't really see any other companies jumping in. |
![]() | #31 |
Yes, the rear steering linkage is sloppy due to the standoff required. However, depending on what your plans are you can get a servo reverser lead http://www3.towerhobbies.com/cgi-bin...?&I=LXAFN1&P=7 or you can install a Hobbic CS-170 http://www3.towerhobbies.com/cgi-bin...&I=LXNRN6&P=ML which rotates in the opposite direction of the stock servo and Futaba servos. Then, install the same style linkage as used on the front. This takes all of that slop out. Just depends on if you were going to upgrade the servos anyways which route to take. Another option is like Jet is going to do and that is eliminate the rear steer. Hope this helps guys. J |
![]() | #32 | |
Rock Crawler Join Date: May 2007 Location: lacey
| ![]() Quote:
As for the footage of the Duratrax, I am actually somewhat Impressed. yeah, thats right impressed. I honestly didn't thing the Duracrap would move ![]() .02 | |
![]() | #33 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
You can use just the battery that is labeled as number 2 on the ESC, and then short the first battery leads. It will crawl at a normal pace then. Mine is still crawling strong stock. About time to start modding it since I am used to how it drives now. |
![]() | #34 | |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
| ![]() Quote:
I THINK THIS TRUCK HAS POTENTIAL. HEY JRH,WHAT ARE YOU THINKING? TEKIN FXR AND 11V LIPO? OR DO YOU HAVESOME SNEEKY MOTORS IN THE WORKS. | |
![]() | #35 |
Sneeky motors. I haven't been able to test the stock ESC, but it doesn't have a lipo cutoff.
![]() | #36 |
sneeky motors? do I hear a call for mini colbalts ![]() ![]() ![]() ![]() ![]() You could pickup a couple of Reedy 19turn rc18 motors and rewind them for say 45 turns or so. |
![]() | #37 |
Now I Would Be Up For That. Metal Gears Some 35t Or 45t And A Lipo Ready Esc. I Think It Will Be Time To Buy One If Motors Are Availible. Mini Cobalts Would Be A Dream Come True .
![]() | #38 |
Rock Stacker Join Date: Jan 2005 Location: Californ-i-a
Guess its not that good eh? 1 minute and the thing breaks? Guess those videos must the factory ringers. I thought it would be good out of the box. I was planning to get this or the cr-01 since they are the most hated/ignored crawlers. I feel that they have lots of potential. Why was this even purchased as an RTR? Maybe it was free? This is rccrawler and going with anything RTR is just not cool. Actually RTR's aren't ever good at all to begin with. The axles don't look too impressive. Seems like it could've been more sleek and with less material. Again this is only ONE review. I remember there was one picture of this crawler at an office meeting with a bunch of Duratrax Corporation execs wearing their suit and ties (and probably held at an asian country?). Seems like they approve of this product. Makes you wonder just how many of them are real rc crawlers or even know anything about it. $_$ |
![]() | #39 |
Survived the storms last night..... Dont count the this little truck out... I was very unimpressed out of the box but, like the TLT it needs some aftermarket parts to be great. The nice thing is, talking with Jdawg53, Duratrax is on the ball and is making CVD's, rear lockouts etc. I think if you really take a hard look at the axles of this truck you will find them to be clods that are designed for a 2.2 class truck. Im still dealing with some major stall on my rear axle but, I have ideas for that. In my opinion, take it for what you want, buy the ARR for the axles if nothing else...sure is allot cheaper than a berg JRH.. are you just shorting the + and - leads together on battery #1 ?? Last edited by jetboat; 08-05-2008 at 10:42 AM. |
![]() | #40 |
Jet Glad to hear you didn't end up in OZ ![]() If you have any problems feel free to pm me. I will do whatever I can. JRH give me a call at work when you get a minute. J |
