![]() | #81 |
I wanna be Dave ![]() Join Date: Dec 2005 Location: Tax Nation
you can, the problem is that it will send the same amps to both the front and rear motor resulting in no major advantage. The reason we are getting teh stall is because the esc is sending the same power front and back when in reality you need allot more power on the rear because it is under the most stress.
![]() | #82 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
The only way to get rid of clod stall is to have independent throttles. You can use more powerful motors (amp draw) to fight the stall in the back, but you will still get a faster spinning front when the tires unload.
![]() | #83 | |
Rock Crawler ![]() Join Date: Apr 2008 Location: Wrightsville, PA
| ![]() Quote:
For right now I'm going to put the 11 tooth pinion on the motors. Get a little more torque and maybe use a 3s lipo. | |
![]() | #84 |
Pebble Pounder Join Date: Dec 2005 Location: Metro NYC
I got my CC today and I installed a mamba 25. First I wired the motors in series and it worked horrible. Next I wired it up in parallel and it performed much better. I do get the stall but only when the front axle is totally unloaded (spinning) It is fair to say that the electrons follow the path of least resistance in a parallel circuit. I will play with it more this weekend and make my decision....on what to do with the stall. (hoping I can develop a driving style to live w it) but I am enjoying it and I have some ideas for some hop ups (homemade).... ![]() |
![]() | #85 |
Newbie Join Date: Jan 2008 Location: lancaster
duratrax at it again i see i was interested in a clifclimer till i saw that lol
![]() | #86 |
the initia reason I bought the truck was for indoor winter crawling and for that it rocks. The problems come up when you try to push the truck into comp level. Clod stall is absolutly nothing new, hence the CLOD in CLODstall. If you do a search you will find that there are several tricks to it. Once DTX releases an adjustable motor mount we will be able to drop a tooth on the rea easily and that should fix 80% of the problem. Some higher torque motors wll help a ton but wont cure it as the amp draw wont change.
![]() | #87 | |
| ![]() Quote:
I am not sure if the power is seperated in the electronics or not. I gotta get a hold of my buddy I think he has the speedo in his pitbox.... I like the CC and I will figure a way to make it work....even if i need 2 speedos and a stick tx.... ![]() | |
![]() | #88 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Guessing ther isnt enough room to shoehorn in some 540 motors? Thinkin about getting one...
![]() | #89 | |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
| ![]() Quote:
in fact to get more power out of the stock setup, it was common to desolder the small metric gage double wires and replace it with single 16 gage wires and parallel the motors. | |
![]() | #90 | |
| ![]() Quote:
I originally had a series circuit but my testing was on the bench (wheels elevated) and i was noticing the axles would stall under no load... the stalling must come from the poles in the motor under no load the series circuit must open and cause the erratic movement. Once I redid the series circuit and tested it on the ground... bam....it crawls much better just slower....now it is time to volt up..... | |
![]() | #91 | |
Let's not be Dave.... ![]() Join Date: May 2006 Location: HONDURAS...ROCK HEAVEN
| ![]() Quote:
![]() Last edited by cartronicshn; 08-21-2008 at 08:54 AM. | |
![]() | #92 |
I wanna be Dave Join Date: Sep 2004
after reading through this thread iam undecided if this worth the money ? so clod stall and orings as spacers needed are the only problems ? or did i miss anything else ? thanks guys. |
![]() | #93 |
I have mine running pretty good now. I added 3 oz of lead to the front wheels and 1 oz to the rears. It climbs really well for its size. I just installed the 11t pinion on the rear motor. I'm hoping it solves some of the clod stall. I still need to make a 7 and 8 cell 2/3A nimh packs for the front axle. I'm currently running a 2S lipo on the front servo. I think the increased weight of the nimhs up front will help out also. I was hoping to get a vid up by now, but I can't drive and shoot a video at the same time. I'll have to wait for help. |
![]() | #94 |
I wanna be Dave ![]() Join Date: May 2007 Location: Taylors Falls just hanging with the MNRCRC crew.
![]() | #95 |
Newbie Join Date: Jan 2007 Location: Mordor
I got mine today, and the wheelspeed is rediculous. Will try the redneck short to slow it down. Haven't experienced rear stall yet though. What about an EMaxx esc for twin motors? I use one on one of my Axial 2.2 rigs with 2 motors, transmissions and drive shafts. Bought this to experiment around with, and I was one of the very early TLT owners, so I kinda knew what to expect. Shouldn't have to do nearly as much to this to get a decent rig. Looking forward to the challenge....,remember carbon arrow shafts ![]() |
![]() | #96 |
Well mine is sitting in customs until tomorrow ![]() ![]() Edit: Thanks jason for the subforum and JRH for the extra work. Last edited by cartronicshn; 08-21-2008 at 08:54 AM. |
![]() | #97 |
Newbie Join Date: Feb 2008 Location: tulsa
hmm, i have been looking at the scorpions, but i might have to look into these a bit more.
