08-28-2008, 12:21 PM | #41 |
08-28-2008, 01:56 PM | #42 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
Looking good I can;t wait to see it complete with the tube chassis. I've just ordered the Yokomo crawler so I might have to try those cobalt motors. Can you tell me what turn rating they are?
09-02-2008, 10:03 PM | #43 |
Quarry Creeper Join Date: Jan 2006 Location: SLC
What are you using for pinions on your motors John? Mike |
09-04-2008, 09:05 AM | #44 |
Same question as mike's here, i received the motors today and the cc pinions don't fit, smaller diameter shaft, are these 48 pitch standard? i know the pinions i have for the tlt and other rigs i have fit the 454's shaft.
09-04-2008, 09:49 AM | #45 |
I am using the stock pinions from the berg. It is listed on the 454 page, first line-- **For Cliff Climber use the stock Berg pinions work (mod 0.6). Stock Cliff Climber motors use 2.3mm bore mod 0.6 pinions** These also work http://www3.towerhobbies.com/cgi-bin...?&I=LXFEA5&P=7 |
09-04-2008, 10:36 AM | #46 |
Yeah that's what i figured, i drilled out the stock ones (let's see how long they last) while i get some pinions.
09-04-2008, 10:37 AM | #47 |
Should work just fine. I got the truck all running, just no time to take pics yet. I am hustling to get ready for Moab.
09-20-2008, 09:54 AM | #48 |
Newbie Join Date: Aug 2008 Location: Pharr
| Esc
Hi John, did tried the pullers with the stock ESC? And wath did you do with the battery cables that you said you use just one battery pack on the stock ESC? How you do it?
09-28-2008, 10:38 AM | #49 | |
Newbie Join Date: Aug 2007 Location: ...
09-28-2008, 10:43 AM | #50 | |
It is a bug in the firmware, they may not fix it and just update the manuals instead. | |
09-30-2008, 10:48 AM | #51 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
John, I eventually want 454's, but cannot swing them now, so I am going to volt up and gear down a little to play with this CC(couch climber for me). I found 8-10T 48P 2.3mm pinions. I do not know heli's, so I am not sure I understand the 0.4/0.5/0.6 Mod verbage?? What pinions specs are for the stock 380's? 2.3mm shaft. 48P? What about the Integy 1/18 pinion sets http://www3.towerhobbies.com/cgi-bin...?&I=LXKWJ2&P=7 I believe they are for 2mm, but could be bored out easily enough (using two drills). |
09-30-2008, 04:24 PM | #52 |
The stock pinions on the CC are 2.3mm bore .6 mod. 48p is not the same.
10-03-2008, 10:18 AM | #53 |
Rock Crawler Join Date: Aug 2005 Location: Illinois
Sweli You will not be able to use 8-10t pinions on the CC. I suggest you add weight to the front to help get more front traction. The stall occurs because it wants to send power to the path of least resistance......so if your front wheels are in the air or not grabbing, it will send more power to the front. You can add weight to the front wheels, mount one of the batteries on top of the front steering servo. Just a few examples. Hope this helps till you can get the 454's. They are awesome motors. J |
10-14-2008, 12:10 AM | #54 |
Pebble Pounder Join Date: Sep 2008 Location: usa
is the stall caused by the stock esc
10-14-2008, 07:23 AM | #55 |
Jdawg53, Why won't I be able to run 8 or 9T? Is the diameter of the 8 or 9T pinions too small, so I will not get enough motor mount adjustment to mesh well? What about T-400 for $8.99 at Tower? I cannot find specific specs, but supposed to have more power (higher wind count) then the S-400. BTW, my setup is a LOT different then stock. BMV Style Cliff Climber Could not get the stock tires off of the stock rims, even with HIGH heat? So for right now, lead is around inside edge of rim in front. Batts in back to clear front steering. thx! |
10-14-2008, 09:03 AM | #56 |
Stall is not "caused" by the esc. It is caused by the current flowing through the path of least resistance. If the front wheels are in the air or not grabbing then the front is the path with least resistance. So, put one of the batteries on the front steering servo and weight the front wheels. This helps ALOT! J |
10-14-2008, 09:09 AM | #57 |
Sweli You cannot use 8 & 9 tooth pinions because the motor mounts do not allow that much adjustability. I have not tried our T-400 motor. Typically, the airplane motors focus on rpm not torque. I try to order a couple up and try them. I know what you are saying about the tire glue. It is goooood! J |
11-20-2008, 12:24 PM | #58 |
hey john where has your lil truck gone.i was wondering if you had tried the 370 motor in your cc . dose it have the balls to do it. atomic has the pinions for the smaller shaft
12-03-2008, 10:51 PM | #59 |
Rock Stacker Join Date: Nov 2007 Location: Dover, De
Whats the easiest way to jump the 2 pins to run the single pack? I was gonna use a jumper pin like on a computer....it should work.
02-24-2009, 03:25 PM | #60 |
Rock Stacker Join Date: Oct 2008 Location: Athens, GA / Alma, CO
| http://www3.towerhobbies.com/cgi-bin...?&I=LXEW96&P=7 Will this pinion work for the CC with the 454's??? |
