| | #1 |
| RCC Addict Join Date: Sep 2004
| here's some pics of my climber and some small things i have done to it. 1. orings in the outer cups 2. rear steer lock out 3.lowered the body 4.boat sided (im not sure that's whats its called, its not please tell me so i don't continue being an idiot) 4.shaved the leading and trailing edge of the front and rear axles so they are not square. ![]() ![]() |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Nov 2007 Location: Grand Junction, CO.
| looks good, hows it wheel? Last edited by drilldeep; 08-23-2008 at 10:49 PM. |
| | #3 |
| surprisingly well. |
| | #4 |
| Fuzzy Nudger ![]() Join Date: Mar 2008 Location: N. Ridgeville , Ohio
| looks good lets see some pics of the axle mods Last edited by vn1500; 08-23-2008 at 11:38 PM. |
| | #5 |
| not much to show, i just took a dremel and shaved some material off so the edge wasn't so square . i made it more rounded so it would slide over the rocks easier. |
| | #6 |
| Rock Crawler Join Date: Mar 2006 Location: "Crawlerbama"
| nice truck. |
| | #7 |
| | #8 |
| Pebble Pounder ![]() Join Date: Apr 2008 Location: Las Cruces
| Just got mine today, and so far its a fun truck. I added weight to the front tires and changed the connections to deans. I notices that the rear wheels do not stay locked all the time, is this the oring mod that you speak of??? Thanks Andrew |
| | #9 |
| crawling corn ![]() Join Date: Aug 2005 Location: Illinois
| vltchkr If only one of the rear wheels spins (like with an open diff) then yes that is the o-ring mod we are talking about. J |
| | #10 | |
Thanks Andrew Last edited by vltchkr; 09-04-2008 at 10:09 AM. | |
| | #11 | |
hope i helped and didnt confuse you.i tend to confuse myself sometimes. | |
| | #12 |
| OCCUPY RCC! ![]() Join Date: Dec 2005 Location: I am the 53%.
| Rig is looking good. I like the body mounted lower and boat sided. |
| | #13 | |
Andrew | |
| | #14 |
| Thanks Twisted 100% better. Was wondering how and where you installed your batteries? I was thinking a single 11.1 lipo on the front servo split up? or should I use a 4 cell? Thanks |
| | #15 |
| iam satisfied for now running the stock packs. i get plenty of run time and cg isnt to bad. |
| | #16 |
| RCC Addict Join Date: Jan 2008 Location: Lake Michigan
| Anyone know what pitch the gears are? I want some Homles 454s, but that would need metal gears. Cannot do 39+39+9+9+9+9 right now. I found some Heli pinions that are 8, 9, 10 pitch and fit 2.3mm shafts. Thought I would start there for now. Could try a 8 in the front and 9 in the back. (right, or other way to fix clod stall?). Just didn't look hard enough. 48pitch in Holmes thread on his CC. WRONG!@! 0.6 Mod pitch What a pain to find! Some heli's use, but most in smaller tooth count are 0.5mod. not 0.6. Holmes is having some made for 1/8" shaft, but prob not the stock 2.3mm. Last edited by sweli; 10-09-2008 at 10:16 PM. |
| | #17 | |
| | #18 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| | #19 |
| I am currently running 12t in the front and 11t in the rear with the HH 454's. I am also running a 5 cell batt. This setup works very well. J |
| | #20 | |
Does the front fish around spinning a lot? Sorry, not used to clods, I've only had shafty's. You went 5cell to reduce crazy wheel speed from the 454's? Holmes is working on 8/9/10 pinions due anyday I think. I tried running my stock axles (chassis is far from stock, non existent). My 2.2 died after an hour run, so I tried to keep up with all the other 2.2's running, but could not go the same lines. Clod stall happened every steep ledge climb. Stock motors are guuuutttttlessss with 11t pinions. Got front and rear dig working for less then $20. Time for some power though. thx Last edited by sweli; 10-05-2008 at 02:42 PM. | |
| Thread Tools | |
| Display Modes | |
