Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: Bearings!@#$%^&*()
Old 09-06-2008, 01:21 AM   #1
vltchkr's Avatar
Default Bearings!@#$%^&*()
Has anyone changed out the bushings for bearings on there CC? Well I did tonight and boy what a PITA!! Everything went smooth but the Spur gears, The bearings went in fine but the tiny arse c-clip ended up snapping in half Now this would not be a bad situation if I lived somewhere but here! So unless Home depot has this tiny arse c-clip im going to have to drive 50 miles to the closest HS, or order a new one
The bushings are a little slimmer then the bearings so coming off is not a problem. If you are in the process of changing to bearings get the tiniest needle nose pliers out there.
Sorry I had to vent....
Thanks for listening and goodnight
Andrew
vltchkr is offline   Reply With Quote
Old 09-06-2008, 12:10 PM   #2
That REALLY stinks.. I'm lucky I have a hobbytown just 5 miles away.
Greenman is offline   Reply With Quote
Old 09-06-2008, 04:28 PM   #3
vltchkr's Avatar
Lowles had them, but now I need the aluminum links, wrapped the rear ones in half!
HAHA still cheaper then a 1:1
Old 09-08-2008, 08:10 PM   #4
i know someone that could make them for crawling friend....
boost_aholic97 is offline   Reply With Quote
Old 09-08-2008, 09:16 PM   #5
vltchkr's Avatar
I have aluminum rod and rod ends coming soon, stretching it to 12.5" wheelbase. bead locks and memory foam is next.
Andrew
