Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Duratrax Cliff Climber
Thread: Nluv's Cliff Climber Build & Tech
Old 11-14-2008, 07:13 PM   #41
Originally Posted by Nluvwithxlr8ing View Post
Body is painted.
So where's the pics Brandon?
CrawlerGraphics is offline   Reply With Quote
Old 11-14-2008, 10:31 PM   #42
Great build.
NiCk- is offline   Reply With Quote
Old 12-24-2008, 06:27 AM   #43
Hmm, to bad this died off. I am really interested in seeing how it turned out.
thunderwagn is offline   Reply With Quote
Old 12-24-2008, 11:29 AM   #44
Im Brandon
Brandon's Avatar
No way has this died off
Brandon is offline   Reply With Quote
Old 12-24-2008, 12:20 PM   #45
Piktors kind one?
Old 01-13-2009, 04:35 PM   #46
Im Brandon
Brandon's Avatar
Quick update. The 4PK should be here soon, after that I will try out dual esc's and see how far I can push the CC. Should be a blast to drive
Old 01-18-2009, 10:54 AM   #47
Hurry it up, man, wanna see how's that going! And post some pics tooooo!
ccbg is offline   Reply With Quote
Old 02-22-2009, 11:31 PM   #48
Im Brandon
Brandon's Avatar
Wow how about some updates?? Sorry for the delay on this project.
Picked up some more Futaba goodies to finish up this build and take it to the next level.
After I messed with the 4PK programming and mixing for a while I ended up switching to the 4 channel RX for more programming options.
Stared wiring the ESC's. Running them off a single 6 cell pack for now.
Time for a dinner break
Old 02-22-2009, 11:38 PM   #49
Im Brandon
Brandon's Avatar
After dinner I decided to get this rig finished tonight.
Some more wiring completed
Installed a S9156. Yes its overkill, however I am planning on running some 2.2's or some tall and heavy 1.9's in the near future.
Quick flex shot
Body mounted!
Old 02-22-2009, 11:57 PM   #50
Im Brandon
Brandon's Avatar
I went with the setup that Harley posted in the 4PK tips thread. Worked perfectly. Cant wait to get it out on the rocks!
Originally Posted by Harley0706 View Post
Setup:
Channel 1 - Steering Servo
Channel 2 - BEC (optional, if plugged in then remove power wires from ESC's)
Channel 3 - Front ESC
Channel 4 - Rear ESC
First go to Systm
Change Disp-Sel: SRV-VIEW
Go to Menu-T
Change it to Level3 (make sure to go down to EXEC and push +/- at the same time)
Go to PMIX1
Set as such:
Go to PMIX2
Set as such:
Go to SWTCH:
Set like so:
Go to DIAL:
The top two lines are the dials that control the rear mixing:
And that is it. That will give result with this setup. Feel free to PM me or post up any questions
Old 02-23-2009, 08:37 AM   #51
thanks for posting that how to ive been trying to figure out my 3pk and ur instrucktions seen very similar
gigercreeper is offline   Reply With Quote
Old 02-23-2009, 08:50 AM   #52
how hard would it be to put a 540 motor to these axles? cheep bergs lol
BL44ST is offline   Reply With Quote
Old 02-23-2009, 08:54 AM   #53
~THE SCALE SHOP~
can a single rooster crawler handle twin 454s?
STANG KILLA SS is offline   Reply With Quote
Old 02-23-2009, 09:01 PM   #54
I really like the paint job. Simple but sweet.
doubletrouble is offline   Reply With Quote
Old 02-24-2009, 10:51 PM   #55
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Should be fine, at the minimum you can run them in parallel.
Harley is offline   Reply With Quote
Old 02-25-2009, 04:49 AM   #56
i like the angled axels now u woulnt get caught on rocks as much
geekfreek95 is offline   Reply With Quote
Old 02-25-2009, 10:59 AM   #57
Im Brandon
Brandon's Avatar
Actually Harley did that, all I did was quote it and bring it in from the 4PK tips thread ;) Make sure to tell him thank you!
I really doubt its possible. Might require a custom motor plate, but the longer can will interfere with the links and shock mounts at the axle.
Should be fine.
Thank you!
Yup, I think I need to pick up a pair of the 454's. The rig works well but I can see the CC motors not holding up to a lot of weight in the wheels.
Just make sure to leave the front axle square to the ground, otherwise you will kill your steering ;)
Old 02-26-2009, 06:29 AM   #58
Works great, that is what I have been using for several months now with no issues.
J
jdawg53 is offline   Reply With Quote
Old 03-23-2009, 03:23 PM   #59
~THE SCALE SHOP~
what are you using for pinions? (with the 454s) link?
Old 03-23-2009, 08:17 PM   #60
ok, Maybe I'm dumb and should know this but.... What are those little things in line on the red power wires from the esc's? I thought maybe a dig setup but it's just inline. Maybe a fuse?
BTW This is a sweet cc man. I've wanted one for a while. Maybe now I might just have to lol.
addictedtonitro is offline   Reply With Quote
