Cliff Climber Well, since we kinda took over salgons thread im starting my own. |
i think that was the rite thing to do |
so right now im working on the suspension links. Ill post some pcs in a few |
are those tmaxx links all the same length? i finially put mine to the test and its git to b longer. does crawl better wth the 2.2 hammers than the stockers all trimmd up. the clod stall wasnt realy prevelant either. everthing is still stock jst reconfigured ans still havent broke or stripped nything on this i love these little things"thumbsup" so wats the total legnth wth the tmaxx links:?: |
i just finished and these are revo links and i took them all off and checked, and they are all the same. here are the finished pics, i didnt even have time to run outside, too dark. tell me how it looks and tips no fflash http://i112.photobucket.com/albums/n...t/MVC-033L.jpg flash http://i112.photobucket.com/albums/n...t/MVC-034L.jpg barely a flex shot :] http://i112.photobucket.com/albums/n...t/MVC-035L.jpg |
take off the shock |
truck is way to tall . u need the belly of the truck to be 3 in . nothing wrong with trying to make it longer but u are going about it all wrong. |
you mean like the spring?? im kinda new to crawling, but what would that do to the suspension? |
un do the shocks . set somthing under truck that is close to 3 in. an tell me how long ax to ax is |
the shock are to long u need limit them or u need shorter shocks. ideal u need the belly of the truck 3 in. off the ground |
ok hold on a secc, maybe like ten minutes |
lookin like a monster crawler"thumbsup""thumbsup". r the shox all the way back in the last mounting hole? i think i will give those links a try on mine. will the stock shox still attach:?::?: i would try to run it a little flatter lower the cg |
http://i457.photobucket.com/albums/q...Picture012.jpg here if u look at mine its not all jacked up in the center . this is what u are after |
giger, i tried the stock shocks on the front links, and it had NO support. it wouldnt crawl. the links are perfect for me so far. but the stock shocks can not handle the links. |
so your links are going to make this lil truck like 11.5 or 12 in ax to ax sounds like |
randy, from axle to axle is from like 8-10 inches. |
with the shocks hooked up |
nooo not hooked up |
then the stock shoks should work . mine is 10.25 ax to ax |
my stock shocks couldnt hold it. but ya lets see you do the shocks. id love to hear if it worked. |
