Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: can u dig it?
Old 11-08-2008, 10:57 PM   #1
Default can u dig it?
has nyone set up a dig on these i dont even know were to start
gigercreeper is offline   Reply With Quote
Old 11-08-2008, 11:31 PM   #2
vltchkr's Avatar
Yes I have a rear dig. I will post my build thread as soon as the new body if ready. It was easy, added a NO switch between the Neg wire to rear motor.
Andrew
vltchkr is offline   Reply With Quote
Old 11-08-2008, 11:35 PM   #3
u had to use a 3 chan. radio rite
randy1 is offline   Reply With Quote
Old 11-08-2008, 11:37 PM   #4
cool glad to here it this thing dosent desend to well. did the switch lock the rear or just stop the power i have a M8 three channel will that work
Old 11-08-2008, 11:41 PM   #5
yes it will work i think it just cut the power but im not sure we will have to let him tell
Old 11-08-2008, 11:51 PM   #6
vltchkr's Avatar
It cuts power and will lock up the motor, that was with the stock motors, I haven't really tested it with the new colbolts.
Andrew
Old 11-08-2008, 11:56 PM   #7
cant wait to see it
Old 11-08-2008, 11:56 PM   #8
i have the stockers in mine. how does it lock the motor are your motors wires to the dual motor esc. or reg esc also in series or in a paralell
Old 11-09-2008, 12:06 AM   #9
vltchkr's Avatar
It does not actually power lock, but these motors are geared low and to use it to crawl a tight corner or climb a steep rock it works good. I am using the Futaba 6EX with a Mamba Max with the drag break set to 100%
I will go ahead and take some pics tonight, since I have been saying this for weeks now....lol
Andrew
Old 11-09-2008, 12:22 AM   #10
well thins is wat i found wth a little more research. i will also atemp if i can find the little black box to do so in
Box
Old 11-09-2008, 12:27 AM   #11
that was all bought at radio shack
Old 11-09-2008, 12:29 AM   #12
vltchkr's Avatar
Yes that diagram will lock the motors.
Old 11-09-2008, 12:41 AM   #13
randy1 wat is the box from vltchkr is this wat your setup looks like
Old 11-09-2008, 12:46 AM   #14
vltchkr's Avatar
No I just have the switch between the neg. When I hit the switch I cut the circuit to the motor
Old 11-09-2008, 12:54 AM   #15
i dont have that second servo on mine sience i locked the rear and that is the new home of one of my hump packs
Old 11-09-2008, 12:58 AM   #16
the box come from the shack as well
Old 11-09-2008, 10:27 AM   #17
thakns im gonna go there today and pic them up
