Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: Drews 12.5" WB CC
Old 11-09-2008, 12:36 AM   #1
vltchkr's Avatar
Default Drews 12.5" WB CC
Here is some pics of my stretched CC, I will do the write up tomorrow.
Andrew
vltchkr is offline   Reply With Quote
Old 11-09-2008, 12:49 AM   #2
wow thats raddid u fab those front links or did u buy them
gigercreeper is offline   Reply With Quote
Old 11-09-2008, 01:04 AM   #3
vltchkr's Avatar
The fronts (Blue) are the Duratrax, the rears are 2.2s that I bent to match the fronts. I in boarded the uppers for better articulation. and I raised the upper shock mounts.
Old 11-09-2008, 09:11 PM   #4
i got some high gc axial links front and rear. jst installd them today wat did u use for shock mounts looks like brake line holders
Old 11-09-2008, 11:16 PM   #5
vltchkr's Avatar
actually I fabricated them out of the same steel you see holding the upper links
There just mock up for now, as I will build hoops, I will also incorporate the upper links in the hoop mounts. You know how this hobby is all about building and tearing apart and re building.
Andrew
Old 11-09-2008, 11:27 PM   #6
that is funny i have had mine apart like 4 times now
randy1 is offline   Reply With Quote
Old 11-09-2008, 11:42 PM   #7
vltchkr's Avatar
I think mine comes apart after every outing, I noticed the axle housings get full of crap so I try to clean them out often. + with the new motors and steel gears I want to make sure the main gear is not stripping out.
Cant wait for a steal main gear!
Andrew
Old 11-09-2008, 11:47 PM   #8
wat did those motors wet u back
Old 11-09-2008, 11:50 PM   #9
vltchkr's Avatar
Shipped was about 80 bucks and the berg pinions were 10 bucks shipped.
Andrew
Old 11-10-2008, 09:21 PM   #10
with all the axial links mine ended up at 12in. have u had any problems with the truck getting hung up on the diff housings? i did so i flipped the most outter screw on the suspension linkage mount b. so the philips head is on the bottom in the reccessd hole for the nut
Old 11-10-2008, 10:22 PM   #11
vltchkr's Avatar
I am using 440 rod and bolts for the inbound upper links for the mock up, so I have about 1/8 of these ends hanging. I have not hung up since the new tires the new tires gave me about 1/2 inch more clearance.
Andrew
Old 11-11-2008, 12:15 AM   #12
im running hammers. memory foam in the front and star cut in the rear
Old 11-11-2008, 12:56 AM   #13
vltchkr's Avatar
My buddy has the Hammers on his Ax. So I got these and we can test which ones we like best. Mine are the Flat Irons M3 with Memory.
So far they work very well, but the seem to wear faster then my Moabs.
Andrew
Old 11-11-2008, 08:46 AM   #14
Im gonna go get some losi claws next week and some moabs. how much wieght do u have on the front tires i have 3 1/2 ounses on mine
Old 11-11-2008, 09:03 AM   #15
crawling corn
jdawg53's Avatar
I run one stip of Great Planes lead weight around the outside and one around the inside of the wheel. Works well.
jdawg53 is offline   Reply With Quote
Old 11-11-2008, 01:07 PM   #16
vltchkr's Avatar
I am running a total of 12 ounces it the fronts, 2 sticks in each tire, and I run 3 ounces total in the rear
Old 11-12-2008, 12:03 AM   #17
i need to get some new motors. so i can run some more wieght they work good. but i want to run more wieght these motors seem to be kinda maxed out
Old 11-12-2008, 12:11 AM   #18
vltchkr's Avatar
They are strong motors but they have to much stall, the colbalts have no stall but be prepared to change dog bones every outing. I ordered the CVDs but they will not be in till DEC.
I recommend not buying the new motors until you upgrade to CVDs and metal gears.
Andrew
Old 11-12-2008, 12:25 AM   #19
thanks for the heads up of when they come out. i guess i should wait. but just a little more power and it would be tits. i still havent made that cut-off box yet im gonna do that first that should help right so i can have both front and rear dig
Old 11-12-2008, 12:45 AM   #20
vltchkr's Avatar
The front and rear dig is good to have, but my thinking is if you dig the front your just pushing and if your on slick or sandy rock you would just push out,
I like the rear dig for popping up or coming down steep cliffs. The Mambas brake works great too.
Andrew
