Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: Comparison
Old 11-29-2008, 12:32 PM   #1
Default Comparison
Does anyone have a side by side comparison of the cc and the losi mrc???
ebbet is online now   Reply With Quote
Old 11-29-2008, 05:28 PM   #2
vltchkr's Avatar
The cliff Climber is 1/14 the Losi is 1/18.
Team Losi Specs-
Scale: 1/18
Length: 12 in (304.8mm)
Width: 7 in (177.8mm)
Wheelbase: 8.5 in (215.9)
Weight: 2.04 lbs (926g)
Chassis: Metal Twin Vertical Plate (TVP)
Suspension: Multi-Link
Drive Train: 4WD with Lock differentials
Tire Type: Mini-Rock Claw Tires
Speed Control: Electronic FWD/RWD with Drag Brake
Radio: LSR3000 Radio with Spektrum 2.4GHz DSM
Batteries: 7.2V 1100mAh NiMH Battery
Charger: Included
Wheel Size: 1.9 in (48.26mm) (hex is 12mm)
Kit/RTR: RTR
Body: Pre-painted,Tuber-Style in Red, Blue or Black
Ball Bearings: Complete
Cliff Climber specs-
Length: 14.2" (360mm)
Width: 9" (230mm)
Height: 7.9" (200mm)
Wheelbase: 9.5" (240mm)
Ground Clearance: 3.5" (90mm)
Body-
Length: 11.4" (289mm)
Width: 5.7" (146mm)
Height: 3.9" (100mm)
vltchkr is offline   Reply With Quote
Old 11-29-2008, 05:53 PM   #3
Paypal....arghhhh!!
cartronicshn's Avatar
Also the losi is around $239.00 and the cliff climber rtr is around $139.00, the losi is a better crawler out of the box imho, but the cliff climber has a size and motor on the axle setup advantage, right now i like my losi mrc more than my cliff climber, but that should change when i get some gears i am waiting on
cartronicshn is online now   Reply With Quote
Old 11-29-2008, 05:53 PM   #4
Ok thanx but i ment like a couple pics.
Old 11-29-2008, 07:57 PM   #5
i think alsdo out of the box the losi is better. but in terms of moddifing the cc is the way to go if you like to make changes all time. mine has gone from 9.5wb to 12 to now 11. and the mods for all three of my phases of the cc total was 60 bucks not to mention about 10hours and maybe 4 energy drinks. by the way you can pick up an artr for close to 100 bucks depends were you look.
gigercreeper is offline   Reply With Quote
