Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: Batter size
Old 12-14-2008, 01:36 AM   #1
Default Batter size
Hello everyone,
I am hopefully going to get a cliff climber this christmas
I already have two 6 cell nimh, 3300 mAH batteries, but on the site it said that it needed mini batteries or 2/3 batteries.
Do I NEED 2/3 batteries just because of the size, or will something go wrong if I run both of my batteries I already have?
SDBigBubba is offline   Reply With Quote
Old 12-14-2008, 02:16 AM   #2
vltchkr's Avatar
Originally Posted by SDBigBubba View Post
Hello everyone,
The only problem I see 1. the stock ESC has tiny gauge wire with quake plugs and 2. the size of the 3300, the only place you would be able to fit them is on top of the electronics which throws your CG out the door. You could buy or make an adapter that goes from 1 battery to the 2 on the ESC, there will still be a battery on top of your electronics but not as bad as 2.
if you plan on keeping it mostly stock invest in a couple of sets of these, they will fit nicely on your front servo. DTXC2193
Andrew
vltchkr is offline   Reply With Quote
Old 12-14-2008, 11:42 AM   #3
Thank you
Old 12-14-2008, 03:29 PM   #4
Dang, I thought this was about pancakes.
vegaracer is offline   Reply With Quote
Old 12-14-2008, 07:05 PM   #5
Yeah I spelled battery wrong xD
Old 12-17-2008, 11:13 AM   #6
another battery lead to look for is for the RS4, the connectors are the same as the mini-quake and the CC.
Lestats Ghost is offline   Reply With Quote
