Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: idea's
Old 12-20-2008, 04:18 PM   #1
Lightbulb idea's
alright well i am getting a cc for christmas from my parents as i told them it was a great deal at 89.99 for the artr. so my plan is to push the limits of the axles. my idea's are axial beadlocks with panther cougar tires,all metal gears,eliminate rear stear,change chassis to a 2.2 comp chassis,maxx shocks,and eventually switch to holmes motors and a sidewinder esc. for now i am gunna run stock motors and and a stock mini lst2 esc. any thoughts or idea's?
haynesn12 is offline   Reply With Quote
Old 12-20-2008, 07:58 PM   #2
well i got the beadlocks now and tires are on the way thru lhs. also picked up a j2-tt chassis on the forum so things are taken shape and i dont even have the truck yet
Old 12-20-2008, 08:24 PM   #3
vltchkr's Avatar
I would recommend getting all the metal gears, even the main which TH says comes out at the end of Dec. Also make sure you get the CVDs, I have those on BO also and might see them at the end of Jan.
Andrew
stock motors did this
Pro Line Flat Irons work great
The Holms Hobbies motors are fantastic, but you will be replacing gears every outing
vltchkr is offline   Reply With Quote
Old 12-20-2008, 08:40 PM   #4
Wow. Stockers did that? I have been watching for the cvd's to become available, but no go. Do you need a different Esc for the Holms?
thunderwagn is offline   Reply With Quote
Old 12-20-2008, 08:55 PM   #5
well yea the plan was metal gears and cvd's i have built a few rigs before this. i just wanna see what these little things can do. gotta try somthing differant every once and a while
Old 12-20-2008, 09:17 PM   #6
Mmm. Just did some reading on the Holms. Might have to invest....Haven't even used the stockers yet, but the Holms sound bitchen.
Old 12-21-2008, 12:30 AM   #7
vltchkr's Avatar
The way mine is set up I can keep up with just about anything, since I locked the rear steer I made axle shafts out of 1/4" aluminum. I just need those damn main gears. I found that the CEN Dog Bones FF057 will just fit and they are thicker, so I ordered a set and will let you know how they hold up.
Andrew
Old 12-21-2008, 07:35 AM   #8
for sure let us know how they hold up. cause i they hold up well i might run those instead so i can run the axial stubs and hexes to pull the wheels in a little
Old 12-21-2008, 10:37 AM   #9
vltchkr's Avatar
With the stock stubs and the Flat Irons track is 9.25, wouldn't think you would want any less?
Andrew
