Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: Pinion size
Old 12-27-2008, 12:27 PM   #1
Default Pinion size
What is the pitch for the pinion on the duratrax cliff climber???
Also will this pinion work in the cliff climber??
http://www.ghhobby.com/proddetail.php?prod=1051
ebbet is online now   Reply With Quote
Old 12-27-2008, 03:44 PM   #2
No. There is not an adjustable motor mount. Pinion to small. I believe the Vendetta uses the same pinion.
thunderwagn is offline   Reply With Quote
Old 12-27-2008, 03:59 PM   #3
Remove the adjustable sleeve and use a piece of tubing to make up the support of the missing adjuster sleeve tube. Then use a larger washer. I have installed a 9t pinion on mine, but I havent been able to run it yet as my rear motor was junk out of the box. Duratrax has awsome tech suport and sent me out a replacement yesterday, no questions asked.
blackfoot is offline   Reply With Quote
Old 12-27-2008, 05:27 PM   #4
Good to hear man.
Old 12-27-2008, 05:58 PM   #5
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
The DT uses a module 0.6 pinion. "metric 32p" it is called sometimes.
JohnRobHolmes is offline   Reply With Quote
