| | #1 |
| Pebble Pounder Join Date: Nov 2008 Location: Cincinnati
| How can you make the front wheels turn farther then they go. I have to back up and turn to even go at the slightest turn. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Feb 2008 Location: Dasmarinas City, Cavite Philippines
| What are you running for servo? I have a 645MG with the rear steer locked out and it turns awsome. |
| | #3 |
| | #4 |
| Newbie Join Date: Jan 2009 Location: richmond
| No issues with steering even with 2 inch longer chassis (stock links) |
| | #5 |
| Quarry Creeper Join Date: Nov 2008 Location: Milliken,CO
| I'm having the same problem with the stock servo and the rear locked. |
| | #6 |
| Quarry Creeper Join Date: Oct 2008 Location: fullerton
| mine turns fine even at 13in axel to axel i just have one of the 40 dollar hitec servos. Last edited by gigercreeper; 01-15-2009 at 09:09 PM. |
| | #7 |
| Newbie Join Date: Nov 2008 Location: Vancouver B.C.
| Is the servo pushing it to full lock? What is your castor angle like? |
| | #8 |
| ya are ur end points all the way? wat remote are u runnin stock? |
| | #9 |
| I am running the stock radio and servo |
| | #10 |
| there are a few possibilties that may hinder your steering. If your foams are too soft it will just push the front end around straight. If you have the Knuckles leaning too far forward (+caster) then it isn't actually steering it will be shoving the tires under the truck. The servo may not be traveling the full distance. When you have the wheels off of the ground does the servo push until you hit the knucles on the screws that hold the C to the axle housing? |
| | #11 |
| Newbie Join Date: Jan 2009 Location: Sparks
| MIP makes the front driveaxles for your rig. they claim that can give you up to 10 degrees more steering. there is probably a mod you can do to the front end, but i dont know it off hand. |
| | #12 |
| who sells the MIP front driveaxles? |
| | #13 |
| Rock Stacker Join Date: Oct 2008 Location: Athens, GA / Alma, CO
| What is everyone using for a for upgraded (alloy) tierod and draglink? The blue suspension links and tierod/draglink that Duratrax sells suck. I've broken damn near every one. |
| | #14 |
| ~The Scale Shop~ ![]() Join Date: Apr 2006 Location: KILLEEN TX
| make sure you unclock your front axle, ie axle C's/knuckles straight up and down. upgrade your servo and run a slightly longer servo arm and get rid of that servo saver. should fix all your problems ;) ive got a chassis coming out soon that should help you with this..... |
| | #15 | |
| | #16 |
| Pebble Pounder Join Date: Jan 2009 Location: san marcos
| | #17 |
| keep your eye out... the CCX will be out soon...... |
| | #18 |
| Cool man, hope its good, but nowing your work it probably will. |
| | #19 |
| I stll cant get mine to turn farther all my set up is stock except for the servo transmitter and reciever. |
| Thread Tools | |
| Display Modes | |
