12-28-2009, 07:29 PM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: Milliken,CO
| What to run for a ESC
I am trying to figure out what ESC would be the best to run for the setup I have. The chassis is extended, running 2.2's, banebots, spektrum DX3.0 controller, SR3000 RX, and two 6 cell 7.2 1600 nihm batteries. Any help/feedback/advise would be great. |
12-28-2009, 08:09 PM | #2 |
I joined the Band! Join Date: Aug 2009 Location: Maryville, Tn
the traxxas evx2 is a great option!
12-28-2009, 08:26 PM | #3 |
That will run the banebots fine with two batteries? Are all the evx2 's the same? there are some 2008's new on ebay. Last edited by doubletrouble; 12-28-2009 at 08:52 PM. |
12-28-2009, 08:58 PM | #4 |
Quarry Creeper Join Date: Oct 2009 Location: Florida
I'm runnig a Mamba Micro Pro on 3s LiPo and stock motors, nothing gets hot, and it has plenty of power... the only time I get any stall is when I get a tire wedged into a tight spot, and I can usually 'rock' the tire out of the wedge. You can fully adjust it with Castle link for just about everything... including 100% drag brake!
12-28-2009, 09:12 PM | #5 |
I have a mamba max, I tried it a while back but it did'nt seam to work, not sure if I had it wired right. I was going to use it on my axial build and get something else for my CC.
12-28-2009, 09:12 PM | #6 |
Quarry Creeper Join Date: Oct 2009 Location: Minneapolis
I would say go dual esc's. With a couple programmable esc's you could do many things such as different power output to each motor, mess with the power curves, etc. It also eliminates the chance of power taking the path of least resistance to the motors.
12-28-2009, 09:34 PM | #7 |
gunch, do you think a Punk RC dig help to accomplish the same effect as that? I want the dig in the CC, I'm thinking it would prolly have the same effect as what you are talking about...
12-28-2009, 10:54 PM | #8 |
What about the traxxes xl5?
12-28-2009, 10:59 PM | #9 |
I use the Castle Mamba micro as well, just the perfect size.
12-29-2009, 03:18 AM | #10 |
I originally had the xl5 for a few weeks, you are severly limited... you cannot configure really too much, you are limited to I think a 2s liPo or something like 8.4v... and it's big and heavy. You could try a Tekkin system... they are absolutely tiny, you could mount it just about anywhere...
12-29-2009, 06:42 AM | #11 |
| Not quite the same thing, the punk dig will let you choose what motor you want to cut or dig, but not let you choose output power. With the dual esc's, it's not going to dig, but instead it will allow you to program say 75% throttle in the front and 100% in the rear motor. This will help eliminate stall. Then you could add a dig for even better performance and cut the rear motor when necessary. |
12-29-2009, 10:16 AM | #12 |
12-29-2009, 11:15 AM | #13 |
I'm not sure, good thought. I would think not though since it still has to have the current go "through" the dig for the motor to work when not "digging". Just my thought though, I'm sure you could contact punkrc about it, I heard there a good group of guys and easy to deal with.
12-29-2009, 06:31 PM | #14 |
What is the difference between the mamba max and the mamba micro?
12-29-2009, 09:09 PM | #15 |
Price, size, motor limits, input voltages, etc. For a CC, the micro should be just fine, it handles up to 3s and no worries on the motor limit since crawlers are generally slow.
12-29-2009, 09:16 PM | #16 |
Yeah, I run 3s with the stock motors... I get about 1-1 1/2 hour run time with very little heat, it's more the motors/ESC are warm, definately not hot. The micro is still completely set up to use Castle Link, so the settings are almost limitless on the CC
12-29-2009, 09:45 PM | #17 |
I got my banabot motors wired and tried my mamba max again, I must have had something wired wrong when I tried it with the stock motors. It rocks now. I bought 2 CC's for christmas for my son and daughter so I think I will try a mamba micro in those. Thanks for all the input/help. :-P
12-30-2009, 06:47 AM | #18 |
Not a problem.
01-03-2010, 02:40 PM | #19 |
Quarry Creeper Join Date: Sep 2009 Location: west sacramento
i run 395's and a fxr. will be getting another fxr this payday.
