Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Duratrax Cliff Climber
Thread: Mike's project "CROW"
Old 03-09-2009, 10:21 AM   #1
Default Mike's project "CROW"
I wanna made a scaler based on MOA axles. Simply to try something different. I like the pumkin body, so I need narrow axles. And CC axles can be made really narrow
I started with this:
First step was to disassemble whole thing and put some parts off
Made rear lock by cutting off servo posts and using axial rod ends & balls with PTI turnbuckles
Also used some tunning parts by DTX
Stock & tuned axle comparison
All tunning parts together
(DTX bearing set, DTX steel gears, Axial stub axles & shaved hexes)
Modified dogbones (axial stub axles need more space due to different design of cups)
2.2 rims for 1.9 scaler ? Why not ? (Proline 8-shooter beadlocks)
You can see weights on front wheel and went holes in place of screws
I have nice 1.9 wheels with 2.2 ProLine dirt Hawg tire
As you can see the whole axle is much narrower now
The whole thing should look like that
crawlingmike is offline   Reply With Quote
Old 03-09-2009, 10:48 AM   #2
Nice
Mean this in a good way -
The beadlock rings almost look like 50's wide white walls, which go with the body era!
sweli is offline   Reply With Quote
Old 03-09-2009, 03:24 PM   #3
Originally Posted by sweli View Post
Nice
THX
I like those low profile tires. It's not so common here.
They are smaller than most of 1.9 tires
from left:
Pro-Line Dirt Hawg (2.2 size)
Tamiya Pajero tire
Losi Rock Basher
RC4WD Prowler XS
SDI Trail Doctor
Tamiya Rock Cruiser MT (High Lift)
RC4WD Rock Creepers
RC4WD Mud Thrashers
RC4WD Out Croppers
SDI Trail Doctor XL
RC4WD Rock Crusher M/T
Old 03-09-2009, 04:36 PM   #4
I used Rock Bashers on my recent, first, scaler build. Smallest 1.9 I found without spending a fortune.
Not the most scale looking, but they're OK, and they crawl well.
Hey, could you put a ruler in the pic both vertically and horizontally and post that in a thread called the "ultimate tire size......." in wheels and tires?
Great info!
Old 03-10-2009, 12:39 AM   #5
Cool build !
Like the tires too !
Pete
greasypete is offline   Reply With Quote
Old 03-10-2009, 04:31 AM   #6
D-Wray 4 Prez!
Frankenwheely's Avatar
Bling Bling
Frankenwheely is offline   Reply With Quote
Old 03-10-2009, 11:54 AM   #7
Great info!
That's a good idea. I'll try to make better snap with ruler. But I have only metric one.
Maybe I can also add this pic:
from left:
Pro-Line Dirt Hawg (smallest 2.2 I found)
DTX CliffClimber tire
HPI Yokohama Geolandar
Pro-Line Flat Iron
Pro-Line Hammer
Tamiya Vise Crawler
Losi Rock Claws
Pro-Line Badlands
Pro-Line Moab
Axial Rock Lizards
Panther Cougar
Hot Bodies Rover
IMEX Red Rock
Old 03-10-2009, 12:49 PM   #8
from left:
Pro-Line Flat Iron
Pro-Line Hammer
Tamiya Vise Crawler
Losi Rock Claws
Pro-Line Badlands
Pro-Line Moab
Axial Rock Lizards
Panther Cougar
Hot Bodies Rover
IMEX Red Rock
You should give me some tires.
InFlames is offline   Reply With Quote
Old 03-10-2009, 01:25 PM   #9
Let's go ahead
I will use Czech made MIG 400 12V (3s lipo) low rpm motors (people use them in planes instead of basic 400 motor with gear reduction unit)
$6 per motor
megamotor pages
with double DSYS MD28DCR ESC (also Czech made )
These are new ones with drag brake. I like size and functionality. Easy programmable via prog card.
Motors comparison. As you can see, original motors are 400 size
Mounted on axles
Old 03-10-2009, 01:51 PM   #10
You might be onto something with those motors...hmm..
Old 03-11-2009, 01:24 AM   #11
Nice, i'm going to check the progress on this one! How much are those ESC's each in $? :P
ccbg is offline   Reply With Quote
Old 03-11-2009, 01:43 AM   #12
About $45 each
Old 03-11-2009, 04:38 AM   #13
Definetely post back on those motors and ESCs
1300 KV, you might be onto something.
How much are the motors?
Two ESCs, are you using a 3-4ch radio so you can DIG with it?
Just spent 20 minutes on Mega's site. Lots to make you wonder.
Nice that they carry replacement parts of every part of the motor!!
Old 03-11-2009, 08:03 PM   #14
Keep us posted when you run those motors. Nice to see people trying different set ups. I really want to find a good replacement.
doubletrouble is offline   Reply With Quote
Old 03-11-2009, 09:08 PM   #15
45$ each? Isn't that as much as a mamba 25 (second hand)? ... How do u program it btw? Tell us something more. Yeah, i lost some time yesterday on their website wondering Couldn't find the ESC tho..
Old 03-11-2009, 10:21 PM   #16
That wheel/tire combo almot looks like white walls with them big beadlock rings.
2JSC is offline   Reply With Quote
Old 03-12-2009, 03:22 PM   #17
It's hard to get any specs of these cheap ($6) motors.
The best way is to try them
I'm gonna run it with 4PK radio, so dig is my option.
The replacement parts they have are only for premium class motors not for cheap cans. Still better than nothing.
The pages are in Czech language only, that's why I didn't post a link.
If you want you can see some pics of ESCs, prog card and light module
here
Of course you can buy any other esc, but i like support in my coutry and 2yr warranty
Some parameters of MD28DCRS:
4-12 Nixx, 2-4 Lixx
max amps 28 / peak 38
BEC 5,4V 3A
programmable (every in 4 steps): battery type, cutoff, model type, acceleration, brake, drag brake, thr curve, neutral range, max power/brake limit
Old 03-12-2009, 03:50 PM   #18
What the name CROW comes from ?
The evolution wasn't easy. Finally I got chassis I wanted.
Holes for shocks are following a circle so I can easy adjust suspension as a scaler or a crawler.
I replaced shock balls with axials. The links are also from AX10.
Completed chassis
Some flex shots / this is not the maximum
I like the low CG of this rig
Old 03-12-2009, 04:06 PM   #19
Thats one sharp build. Really like the axles used that way. by the way nice user name
CrawlinMike is offline   Reply With Quote
Old 03-14-2009, 12:11 AM   #20
Question
I really want to here how those motors run! Matt
SDheavymetal is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/duratrax-cliff-climber/166068-mikes-project-crow.html
Posted By For Type Date
2.2" Crawler Reifen im Überblick - Reifen und Räder - rockcrawler.de Post #0 Refback 10-04-2011 03:17 PM
