Hey I have some ???? 1. Will my novak super rooster run my stock 5000 dual motors. And should I run them in parallel or series. 2.Im trying to turn my c.c. in to a 2.2 and I put longer links on the chassie but sometimes when I try to crawl the chassis will get pushed up and shortin the wheel base how do I fix this.. Thanks |
How many cells are you going to run through the super rooster? I think it should handle the stock motors just fine. I run mine in parallel, but have some clod stall so far. Still perfecting the motor and pinion bit. |
I dont know if I should run the two 1600 2/3 or one 3600 6 cell. |
i got a 3000 6 cells on the front. get about 15 mins of run with the 454's in parallel . |
6 cells with the stock motors doesn't have any power. I've been using 7 cells, since that is what my esc will handle, and it is barely enough to have fun with. If your going to use the stock motors 12 cells is a must imo. |
