04-13-2009, 09:23 PM | #1 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
| Brushless option for Cliff Climber????
A new brushless option for the c.c. ??http://www.traxxas.com/products/elec...tro/intro4.htm motor may not be the best for crawling..... but the ESC is dual battery ......6-12NiMH cells up to 3s Lipo! the more 380 stuff/ small scale 1/16,1/18,etc. the better I say I want both! Last edited by R/CMaxximus5.0; 04-13-2009 at 09:52 PM. |
04-13-2009, 09:49 PM | #2 |
Rock Stacker Join Date: Mar 2009 Location: Titusville
I'm sure that it would be a good setup, but a little pricey for 2 motors and ESC's. Castle Creations currently has 28mm dia. (about 380 size) motors in the works, and I would rather wait for those since there will be a wider range of kv's to choose from and more adjustability with their ESC's. I don't think the traxxas ESC has adjustable drag brakes, but being waterproof is definitely a piont in its favor. I am still itching to drive the mini E-Revo. |
04-13-2009, 09:57 PM | #3 | |
Yea, I want both of them! -I am wondering if they are standard size NiMH cells or if they are 2/3A cells? | |
04-13-2009, 11:38 PM | #4 |
While it is theoretically possible to run 2 brushless motors on a brushless ESC, the ESC wouldn't last very long, not because of the current draw, but because of the difference in timing. If the motors weren't turning EXACTLY the same and either motor EVER slipped, the ESC wouldn't know when to gate the SCR's on to create the three phase AC. Sensorless brushless ESC's use back emf to detect rotor position, and it is not possible for the circuit to reconcile two separate signals. It would effectively think that the rotor was in two places at the same time, or part of the signal would be filtered out and there is no way to know which part of the signal from either motor would be lost. Email Joe Ford from castle creations for a more detailed explanation. So, I guess the short answer is no. I am only planning on getting the mini E-Revo, but I have to unload some stuff on eBay before I do. The wife thinks 36 RC vehicles is too much, but she fails to realize that the kids have 5, and she has 14, but it only counts when I want something new. |
04-13-2009, 11:39 PM | #5 |
04-14-2009, 01:03 AM | #6 | |
04-14-2009, 09:19 AM | #7 |
I am currently using a traxxas EVX-2 and $3.50 motors from banebots, and I couldn't be happier with the performance. I need to tune it down a little so my gears live longer. Maybe run it on 8 or 9 cells instead of 12. There really isn't any reason to make the CC brushless, and I would rather have the setup I've got right now than a dual brushless. It has axle snapping, gear crushing torque, it is still very controllable at low speeds, the motors are dirt cheap, and it has smooth throttle response.
04-14-2009, 10:05 AM | #8 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
| 750kv 380 Brushless http://www3.towerhobbies.com/cgi-bin...?&I=LXLWT5&P=7 $24ea 750kv 28mm dia 30mm long Needs mount adapter No specs on stall, etc. |
04-14-2009, 10:06 AM | #9 | |
04-14-2009, 01:30 PM | #10 |
| Nope. It is the overwhelming insane torque, combined with the outstanding traction of the proline flat irons. I let my buddy drive it, and he got a wheel stuck in a crevice in my rock pile. He tried to ease through it slowly, and I guess the tire was bound up pretty well because that is when the counter gear stripped.
04-14-2009, 05:46 PM | #11 | |
Quarry Creeper Join Date: Nov 2008 Location: Milliken,CO
Are you using metal gears? | |
04-14-2009, 07:05 PM | #12 |
you can not run 2 BL motors off 1 BL esc. you would have to run twin BL escs
04-14-2009, 07:21 PM | #13 |
04-14-2009, 11:56 PM | #14 | |
04-15-2009, 12:57 AM | #15 | |
enjoy! | |
