07-16-2009, 12:00 AM | #21 |
Newbie Join Date: Jan 2009 Location: Milwaukie
Anyway you could post an engineering drawing? I have been wanting to make a chassis but I don't have the dimensions and I think I will screw up |
07-17-2009, 08:35 PM | #22 | |
Rock Crawler Join Date: Dec 2007 Location: St. Cloud
I take no credit for the design of the chassis, I found this page a long time ago and used one of John North's designs. | |
07-17-2009, 09:46 PM | #23 |
RCC Addict Join Date: Aug 2005 Location: Naoma, WV
I'm working on a Widow LP chassis, designed by Offroader5, for my TLT crawler right now. Unless you're running a wheely king though, you'll need to make some changes. It's nice to have a start though, and printing off templates makes fabbing almost brainless, haha.
07-17-2009, 11:52 PM | #24 |
Stock design seems to work well with the CC axles as I built it, I am using another one of his designs for a scaler based off of the Tamiya Pajero. I love working with Delrin, it is so easy to deal with and it holds up great to the abuse I put it through. All the work I have done has been using woodworking tools. It dulls blades and bits fast but it is worth it.
07-18-2009, 12:10 AM | #25 |
So you used the widow lp version? Did you have to modify it?
07-18-2009, 12:34 AM | #26 |
Yes, I used the widow lp. I did not modify the chassis. I made a custom skid, links, and used Duratrax Evader ST front shocks on all 4 corners. Sorry, I did modify it a little, I drilled additional holes for the upper link mount so i could use what worked the best. I used the spacing on the drawing and drilled the chassis all the way down to the bottom skid mount. I am using a hole almost in the middle for my upper link mounts. Last edited by fixed13; 07-18-2009 at 12:38 AM. |
07-18-2009, 06:34 AM | #27 |
I did the same thing, ended up swiss cheesing the original design for different upper link and shock mounts.
09-27-2009, 10:20 PM | #28 |
This rig is now for sale, check the for sale section on here for all the details. You can also PM me.
