| | #1 |
| Rock Stacker Join Date: May 2009 Location: Baton Rouge
| What are u guys useing to make new upper/lower links? THANKS |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Aug 2005 Location: Naoma, WV
| I use #8 all thread and revo ends, then sleeve the thread with whatever. |
| | #3 |
| Rock Stacker Join Date: Jun 2007 Location: Sacramento, CA
| | #4 |
| Rock Crawler Join Date: Dec 2007 Location: St. Cloud
| I used 5/16 delrin rod, drilled and tapped the ends for 3mm x 20mm set screws and attached traxxas rod ends. I used a link drill bushing to center the hole and drilled it with a cordless drill. Link to the bushiings: Link Drill Bushing Some pics of mine: |
| | #5 |
| Rock Stacker Join Date: May 2009 Location: Chester VA
| Quick question too while on link talk, once youve made longer links, do you have to move the position where the shock mounts? I tried to make some but it seems that maybe the links were too long and I would have to mount the shock in a another place other than the axle. Any help? Thanks |
| | #6 |
| If you make long enough links the shocks just wont reach. If that is the case you can make chassis extension plates, A new chassis or make a bracket for the front axle to mount the shock closer. |
| | #7 | |
| Newbie Join Date: Jul 2008 Location: Jefferson
Those are really sweet. Does delrin make that much better links than aluminum?? I know its slick but ive never worked with it so im a little more intimidated by it. | |
| | #8 |
| Those are really sweet. Does delrin make that much better links than aluminum?? I know its slick but ive never worked with it so im a little more intimidated by it.[/QUOTE] The big advantages of Delrin are the fact that it is slick and easy to work with. I use woodworking tools to cut the Delrin and it drills and taps very easily. I have heard that it breaks easyer but all my stuff has held up well. If it does break it is easy to make a new piece. Link to my build:CC and Delrin |
| | #9 |
| I'm a big fan of the plastics as well, mostly lexan and acetal(delrin), but I also use regular cutting board plastic for things. Like fixed13 mentioned, very easy to work with, I use router bits in my drill press to make it a hillbilly mill. |
| | #10 |
| Rock Crawler Join Date: Jan 2007 Location: Tuscaloosa
| I used the stock links, threaded rod, and aluminum tubing. |
| | #11 |
| Router bits in the drill press? Ouch, watch you digits. My fingers show what router bits can do, 18 years in a woodshop has its dangers. |
| | #12 |
| Well, I have a mill vice, so I keep my fingers on the wheels for that. It always takes a few scars before we think of safety doesn't it? I have my fair share from shop tools as well. |
| | #13 |
| Rock Stacker Join Date: Mar 2008 Location: Moundsville
| Delrin is the way to go, easy to make and they work great. |
| | #14 |
| delrin is looking to be my links in the near future then. ;) |
| | #15 |
| | #16 |
| How did you pre-drill the links? |
| | #17 |
| Is there a place to get those delrin rods at a decent price online? No one near me sells delrin that i have found. |
| | #18 |
| eplastics.com http://www.eplastics.com/Plastic/Ace...4Pa38Ta38QaNr0 I have bought acrylic from them before and they seem to have the best prices. They will also cnc cut parts for you if you send them cad drawings. I am thinking about having them cut me a chassis. Although it is easy enough to do in my garage so i don't know. Last edited by badtoy1986; 06-07-2009 at 08:19 PM. |
| | #19 |
| SWEET. thanks dude! |
| | #20 |
| Thread Tools | |
| Display Modes | |
