06-07-2009, 11:39 PM | #1 |
RCC Addict Join Date: Jul 2008 Location: San Diego
| Drag brake
I installed a FX R on my sons CC and the drag brake doesn't work. Is that because of the duel motors? Hes running a 3 cell lipo and banebot motors. We keep braking the metal gears.
06-08-2009, 12:20 AM | #2 |
Rock Stacker Join Date: Jun 2007 Location: Sacramento, CA
Are the metal gears junk? I have not heard to many people stripping the plastic gears even with the banebots motors.
06-08-2009, 05:50 AM | #3 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
The plastic gears are junk for me. Still deciding weather or not to shelf my ride or spend $80 for metal gears to be able to just run it and I am using vendetta motors.
06-08-2009, 08:29 AM | #4 |
Rock Stacker Join Date: May 2009 Location: Grand Blanc
With the Banebots motors, or faster motors try running a single pack or 2s lipo and the plastic gears will hold up just fine. It won't be nearly as fast as dual packs or 3s lipo, but at least it will stay running
06-08-2009, 09:26 PM | #5 |
Rock Crawler Join Date: Dec 2007 Location: St. Cloud
| I don't see how dual motors would effect the drag break, does the FXR have different drive profiles? (Is the brake shut off, like on some other esc's)
06-08-2009, 09:39 PM | #6 |
The Tekin has 11 steps/setting just for the drag brake. Not sure with the double motor stuff. Its set to 11 the hightest. On my Axial if I let off the throttle fast it will endo because th brake is so strong. My son seems to brake a lot of stuff. He is 14 years old and bashes all his R/C stuff.
06-09-2009, 06:49 AM | #7 |
I am running a single gp3300 pack with a sidewinder esc and if I pull full throttle, it will pull the front wheels about and inch and the rear counter gear breaks. It happened twice. Then just crawling over a pillow at half throttle, broke another one. I am afraid to run it again. But downhill, the 40% drag on the sidewinder has held at almost 45* on a piece of plywood. This is an awesome controller for crawling.
