06-27-2009, 06:29 PM | #1 |
Pebble Pounder Join Date: Jun 2009 Location: Florence
| 2.2 tire question
Hi this is my first post on the site. Great place! Just got a cc about a week ago and have a question about tires. If I put on a set of 2.2 tires like Panther Cougar 2.2 Crawler tires, will I be more likely to break parts such as gears? If so how much more likely? Will it be a sure thing or maybe just possible if I run the truck hard. What about body clearance, would I need to cut the body at all? I have the stock wheel base and would like to keep it like that for now. Would new tires make a big difference with crawling or are the stock tires already pretty good? A few comments on the truck itself. This is my first crawler. Picked it up at tower for $109 for me and my two boys. So far I am pretty impressed with it. Did some very small stuff for the first couple of packs and was surprised at how well it did. Took it to a construction site today for some bigger stuff. I thought it did very good for the size it is. Then I broke the rear main gear output joint. I kept on running it and even with that broke it was still hanging in there and doing a good job. After a bit I broke the front one also so that was it for the day. I have some steel ones on order and plan on shimming them with an o-rings. I also have a pair of 645mg servos on order and metal servo horns and some traxxas links to clock the drive shafts and also a 12t gear for the front motor. I'm really looking forward to seeing what the new parts do for the truck. Thanks for any help with the tire question and great site. |
06-27-2009, 06:39 PM | #2 | |
Pebble Pounder Join Date: Dec 2008 Location: Columbus, IN
06-27-2009, 10:40 PM | #3 |
So I should consider replacing my gears with metal gears if I get some 2.2 tires? What are some good 2.2 tires for the cc if I get some. Any considered better for the cc than others?
06-28-2009, 06:11 AM | #4 |
Rock Stacker Join Date: Jun 2009 Location: Mesquite
It is worth it. I put some proline moabs on mine and it is so much better. A lot more clearance in the center of the axle to get over stuff. Also the the larger tires will go over more without getting hung up.
06-28-2009, 10:39 AM | #5 |
Rock Stacker Join Date: May 2009 Location: Chester VA
I am running 2.2 RPM revolver wheels with 2.2 Losi Rock Claws...it is the best mod ive done yet...I run my rig fairly hard and have yet (knock on wood) to break anything. The claws are much softer and taller than the stock cc set up. My cc is stretched to an 11" wb and soon to be 12.5" wb. I think you would be happy with a bigger tire.
06-28-2009, 12:02 PM | #6 |
well I have been looking around and I am considering losi rock claws with some jconcepts tense wheels. any opinions about this combination?
06-28-2009, 10:01 PM | #7 |
Pebble Pounder Join Date: May 2009 Location: ashland
i put my stock axial 2.2 wheels and tires on my boys CC and stripped the out drives on the front and rear axles. $17 for new steel units for the two axles. I would recommend ordering those along with the new wheels and tires.
