| | #1 |
| Quarry Creeper Join Date: Mar 2007 Location: Martins Ferry,OH
| ok im buying the cc rtr from my local hobby shop but what battery and charger can i get thats cheaper. i already have a nylint crawler and charger but idk if it will fit or work Last edited by geekfreek95; 06-29-2009 at 06:20 PM. |
| Sponsored Links | |
| | #2 | |
| Pebble Pounder Join Date: Dec 2008 Location: Columbus, IN
| | #3 |
| Rock Crawler Join Date: Dec 2007 Location: St. Cloud
| The battery you need is a 2/3A 6 cell stick pack with the HPI/ Duratrax mini plug. Those batteries (or ones like it), are used in all Duratrax 1/18th vehicles and some other ones. Try ebay for cheaper battery's or cheap battery packs dot com. |
| | #4 |
| ok i talked to a friend and i think his will fit with an adapter |
| | #5 |
| Rock Stacker Join Date: Nov 2008 Location: Fisher
| I would get rid of the stock end and put a deans connecter. |
| | #6 |
| | #7 |
| will this battery work if I get the right adapter? http://cgi.ebay.com/ACE-2-3A-6V-1600...3A1%7C294%3A50 |
| | #8 | |
![]() ![]() The battery you pictured has the wrong cell configuration and I can't point you to the right adapter, the plug on it looks like one for a Heli or a radio. | |
| | #9 |
| Pebble Pounder Join Date: Jan 2008 Location: el paso
| those battery packs are 5 cells only giving you 6.0volts, you might experience a lot of clod stall on climbs. |
| | #10 |
| RCC Addict Join Date: Aug 2005 Location: Naoma, WV
| Yeah the CC is originally meant for 12-cell. 6-cell and it's weak, 5 and it may not even run depending on your ESC. And if it does, like teamvaladezhobb said, no torque at all. |
| Thread Tools | |
| Display Modes | |
