| | #1 |
| Pebble Pounder ![]() Join Date: Jun 2009 Location: Florence
| i just got 645mg servos for the front and back. i like the rear steer so i would like to keep it. what i don't like is the vertical rod that makes the rear steer awful. how can i keep the rear steer but get rid of this rod? |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Dec 2007 Location: St. Cloud
| Some servo's rotate the opposite direction of the stock ones. The 645mg are that way, what I did was use the 645 up front, reverse the servo and move the rear arm to the opposite knuckle. I used the stock servo in the rear so they rotated in opposite directions. The front servo does most of the work so I figured that the rear would be ok as stock. I hope this makes sense, and unfortunatly I don't have any pics and I have since locked out the rear stearing. |
| | #3 |
| Rock Stacker Join Date: Jun 2009 Location: Mesquite
| I think you are talking about the spacer that raises the steering link. If so just get a longer screw with a nyloc nut and attach the link from the servo on top of the link that goes from side to side. I also used a non locking nut in between the 2 links. I have locked out my rear steer so do not have any pics of how I had it. You will also need to reverse one of the servos or the wheels will turn the same way and just crab. here is the link to reversing a servo. Step by Step Servo Reversing Last edited by lt1zwb96; 07-14-2009 at 12:01 AM. |
| | #4 |
| Quarry Creeper Join Date: Sep 2008 Location: Missoula
| On the CC I've been messing with I got rid of the big spacer, flipped the servo horn so it points down and bought a reversing Y harness. The harness cost about 8 bucks. |
| | #5 |
| Thread Tools | |
| Display Modes | |
