Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: Cable adapter for running with 7,2 standard acc
Old 07-28-2009, 06:41 AM   #1
Default Cable adapter for running with 7,2 standard acc
Will buy a DTX cliff Climber from TowerHobbies, but want to run with my standard 7,2 accs and Tamiya connector,s whats the name of the Duratrax connector, is it a standard connector?, is there any adapters available, what do I need?
us_scandinavian is offline   Reply With Quote
Old 07-28-2009, 11:09 PM   #2
This should be what you are looking for.
http://www3.towerhobbies.com/cgi-bin...&I=LXUUR8&P=ML
fixed13 is offline   Reply With Quote
Old 07-29-2009, 02:48 AM   #3
Thanks, should be like that, but reversed, has looked at that one, it is for charging a 2/3 acc in a charger with Tamiyaplug, cant find anyone with Tamiya female and micro male.
The alternative is to cut the micro plugs in the Cliff Climbers esc and mount Tamiyas, this was available for solderless mounting.
Click the image to open in full size. Click the image to open in full size.
Alternative;
Old 07-29-2009, 10:36 PM   #4
Sorry, I must have read your post to quickly. I guess I have never looked for adapters, I always just make my own. The most common name for the Duratrax plug is, HPI Micro. Why not just order the plugs you need and make your own, it will be the correct length for sure then, most adapters I have seen have been real short.
