Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: Good, affordable waterproof ESC?
Old 07-29-2009, 04:58 PM   #1
sns
Default Good, affordable waterproof ESC?
Hello,
I am thinking of using a CC for a project, and I wanted to get a second opinion from a few CC owners.
The truck would see trail use and some crawling...just for fun, nothing serious. I want it to be mud/snow capable as well, so I am in search of a waterproof esc that can handle the twin motor setup. Wheels and tires would be similar to stock or 1.9s with a 4" OD. Batts would either be AA size or 2/3A size...two 5 cell packs. Here is what I am considering:
Mtroniks marine 25
http://www.mtroniks.net/details1.asp...r-marine25.htm
The stock DTX esc is rated at 20A continuous, 60A surge (according to towerhobbies) for up to 14 cells, so I assume the 25A esc would be okay. Would the 25 amp esc be able to easily handle the stock cc motors (wired in parallel) on 10 cells? banebots 390s (parallel) on 10 cells?
Any other suggestions?
Thanks in advance for the input.
sns is offline   Reply With Quote
Old 07-29-2009, 06:24 PM   #2
Traxxas EVX-2 (blue) 16.8v ESC would be a good choice.
R/CMaxximus5.0 is offline   Reply With Quote
Old 07-29-2009, 06:59 PM   #3
sns
Yes, the EVX-2 would do the job, no doubt about it. But, I was trying to find something less expensive...since the evx2 is more than twice the amount of the prebuilt CC. Any other esc's come to mind?
Old 07-29-2009, 08:50 PM   #4
maybe try to find a used one?
The stock ESC is 1.5 times as much $$ as the prebuilt too.
Old 07-29-2009, 08:57 PM   #5
sns
hmmm...I never thought of a used one, I'll have to look into that. As long as I use an esc rated for 20A or more, I shouldn't have a problem though, correct?
thanks again for the input...I'll have to snoop around ebay a bit
Old 07-29-2009, 10:25 PM   #6
That should be correct, but I think the EVX would be your best bet.
Your location says St. Cloud, can I assume that is MN?
fixed13 is offline   Reply With Quote
Old 07-30-2009, 02:17 PM   #7
sns
Yep, St. Cloud, MN. Been bashing for a while with a stampede, but just recently getting into the trail rigs/crawlers...fun stuff, love the long runtimes! thanks again all...think i might give the mtroniks a try.
Old 07-30-2009, 02:58 PM   #8
I use these in my 1:8,1:10 scale rigs and they work great.
http://www.horizonhobby.com/Products...ProdID=PRB2314
ScalerLover is offline   Reply With Quote
Old 07-31-2009, 10:09 AM   #9
sns
Sweet, That's exactly what I'm looking for. I am going to give that Pro Boat ESC a try. Thanks!
Old 07-31-2009, 10:38 AM   #10
I actually was in the same boat as you sns for an esc...I ended up going with the EVX2...found one for about 55 shipped and it comes prewired for dual motors and dual battery...I think it will perform the same if not better as the stock esc but this one is more reliable than the stock. Just an input. Good luck on your choice and let us know how it works!
09xD is offline   Reply With Quote
Old 07-31-2009, 01:25 PM   #11
It will perform much better than the stock garbage. I have not run it in my CC but the one I had in my Emaxx was flawless.
Old 07-31-2009, 11:54 PM   #12
Awesome! Should be here tomorrow...will definitly let you all know how it turns out.
Old 08-05-2009, 09:11 PM   #13
What about the stock slash esc. cheap and waterproof.
Flyin Hawaiian is offline   Reply With Quote
Old 08-05-2009, 09:36 PM   #14
I got my evx2 in on monday and wired up...took it for a nice hard trail ride today and the evx2 will definitly do you well...it performs so much better!
Old 08-09-2009, 08:40 PM   #15
stock slash can be had for less than 40 and should work great
wakeboardfusion is offline   Reply With Quote
Old 08-09-2009, 09:02 PM   #16
Slash ESC is 8-cell max isn't it? That won't cut it in these rigs.
Jamus is offline   Reply With Quote
Old 08-10-2009, 06:24 PM   #17
ok forgive this question if it is stupid, but i am a bit more into this hobby for the fabrication and not the electronics. So you have a water proof esc, but aren't your motors still in danger of being damaged by the mud or snow or whatever watery substance you drive through?
i definatly see the advantages of not having to bring my rig in because it stats raining or waiting till it drys up before i can bring it out
furiousgeorge is offline   Reply With Quote
Old 08-10-2009, 09:49 PM   #18
most of the danger to electrics is the charge jumping across circuits, with a motor this is not a risk, since the motor is just a circuit a basic positive and negative going straight across a short will not damage it.
foproy is offline   Reply With Quote
