Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: MY cliff climber build thread!!!
Old 08-16-2009, 08:03 PM   #1
Default MY cliff climber build thread!!!
hay i bought a drx cc about 2 weeks ago and felt like i needed a little more ability out of it so im now running a traxxas xl-5 waterproof esc, along with a traxxas 4 channel 27mhz resiver, with a traxxas tq transmiter. im using a hextronik hx12k hi-speed servo only one because ive locked the rear steer out. i have the wires wiered parrell instead if in a series. it is powered by 2 2cell 20c 1750 zippy lipos, with high current deans plugs. im also running 11t pinions front and rear for more torque. ive made homemade rear links out of traxxas rod ends and 6:32 allthread. tops are 108mm and bottom are 116mm makes the wheel base 10.5 inches, i plane to make the same front links so the wb should be around 12in, and should also clock the front axel. tire weights are on order!!
http://i987.photobucket.com/albums/a...zz/p_00295.jpg
any suggestion would help with what you think i should do next
cdw327 is offline   Reply With Quote
Old 08-16-2009, 08:15 PM   #2
sounds like you got it figured out!!and by the way one of the cheapest things you can do to help it is throw some 2.2s on there. helps it all around!
TNCrawler is offline   Reply With Quote
Old 08-16-2009, 08:19 PM   #3
also you should cover that thread rod up with some tubing.....1/4 should work well. it would slide over rocks alot easier! very nice rig though!
Old 08-16-2009, 08:22 PM   #4
thanks alot i was thinking of trying to make this a scale truck so maybe some 1.9's but then i would need to figure out how to make them fit the axel? and about the tubing i got some in the garage right now just havent had gotten around to do it yet. what do u think about the 1.9 some how or other scale size?
Old 08-17-2009, 08:49 AM   #5
does any one know how to et more rotaion out of the front wheels. now that ive locked out the rear steer it needs some more rotaion in the front?
Old 08-17-2009, 04:16 PM   #6
heck i would just do a 2.2 scale just narrow the tires a bit and i think it would look sweet!
Old 08-17-2009, 05:04 PM   #7
how would i go about this
Old 08-17-2009, 07:38 PM   #8
try I lil longer sevro arm thats what I did on mine
will916691 is offline   Reply With Quote
Old 09-03-2009, 02:32 PM   #9
Default Update!!
i order some scale parts, to turn it into a 1.9 scale chevy 454ss! i went with the tcs proto ctrail frame, with tamiya high lift wheels, and tires. also i won the chevy body on ebay for $5. i plane on painting the inside of the truck rust color, and the out side white, so when it gets scrached it looks like rust haha. will post pics when the parts arrive!
Old 10-03-2009, 03:41 PM   #10
CC now a 72 454ss pick up!
TCS CHASSIS
TRAXXAS XL5 (waterproofed)
TRAXXAS 4 CHANNEL RESIVER (waterproofed)
HEXTONIK HIGH SPEED SERVO (waterproofed)
RUNNING LIPOS (1750) (waterproofed)
TAMIYA HIGH LIFT WHEELS/TIRES
I used the stock suspention, links, and springs. I trangulated the bottom links, and made my own skid plates.
I water proofed all the elctronics, using plasti-dip.
I still ned to finish the body, and coat it with plsti-dip to make it stiffer, and i made a snorkel out of a manifold i had laying around from a nitro car. i still need to cut the body post so they dont stick out so far. shes ready for the water, and mud!! i hope
http://i987.photobucket.com/albums/a...z/109_0094.jpg
