does this radio work? does this radio system can work on my cc? This is Futaba's 2PH MS (Magnum Sport) 2-Channel AM 75mhz Pistol Grip Radio, with One S3003 Standard Servo & receiver. Futaba # FUTJ1364 FEATURES: This replaces the 2PC Magnum Sport Radio. Rotary steering and throttle trims. Two LED battery condition indicators. Lightweight and ergonomic design reduces fatigue and improves control. Red rubber grip at the fingertips. Servo Reversing switches hidden behind Smoked panel. INCLUDES: One 2PH AM Transmitter w/TX Battery holder. One R122JE AM Receiver. One Crystal Set (75MHz). One Receiver Battery Box w/Red BEC connector. One S3003 Servo. One Servo Accessory Bag One Flag Set. One Switch Harness. One TX Antenna. One Battery Holder. REQUIRES: Eight AA batteries I need to know this now plees help me |
yes it should work fine |
tnx man |
no prob"thumbsup" |
it should work ok, but be prepare for glitches...Best is to use Spektum radios...I have zero issues with it for last 2 years. before that I had an AM radio similar to the one you wanted... ran fine, but get quite a bit of glitches when loaded (climbing steep hill or using dig). Using bec helps very little. Just my experiences. If you have a bit of cash, get a Spektum radio. You won't be disappointed. |
i have that same radio and it works fine for the last 3 years it has glitched a bit but it was to close to my esc. just keep it as far as possible from the esc. |
does the stock radio system is better? and if yes can you give me alink from ebay? and I dont have to much money roy |
