10-26-2009, 08:57 PM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Minneapolis
| Getting sidewinders, any tips for setting them up?
I installed banebots and was having problems with the stock esc shutting down. Well, I picked up a couple CC Sidewinders and was wonder if there was anything I should know about programming them and installing them. Talon |
10-27-2009, 08:20 AM | #2 |
RCC Addict Join Date: May 2009 Location: Weston
Are they the 1/10th sidewinders? Are you using two of them? I tried to use two on my two channel by splitting the reciever wire but it did not work well at all. I set them both upon my castle link exactly the same but one would always be more responsive then the otherso I went back to one.
10-27-2009, 12:33 PM | #3 |
I think their the micros, I just got them off of flebay. I will only run one if I can as it takes up less room but I thought I might need two. Are you running an external BEC with it? Also what motors are you running? edit: I was thinking the same thing about splitting the receiver wire or running them in parallel. Or getting a tq3 and receiver as they are pretty cheap. Last edited by gunch; 10-27-2009 at 12:34 PM. Reason: added stuff |
10-27-2009, 12:36 PM | #4 |
I am running a ccbec, banebots, but I use the 1/10th sidewinders. I'm not sure if the micros can handle both so its probablt a good thing you got two. |
10-27-2009, 01:43 PM | #5 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
I am running Banebots on a single CC Sidewinder Micro, on 8 cells. They will handle 9 cells or 3S Lipo. Above that you will let the smoke out. Vertually no drag brake though, even with it set to 100%. |
10-27-2009, 06:58 PM | #6 | |
Are you also running an external BEC or not? How strong of servos are you guys running? Just want to get this right the first time around, I'm getting sick of trying new things and finding out they don't work. Thanks guys | |
10-27-2009, 09:07 PM | #7 |
Newbie Join Date: Oct 2009 Location: festus
what is cc stall? just got a cc that is stretched with 2.2 bead locks i used two 1100 6 cell battries over each axel i dont know if that is right the rest is stock thankx for any help
10-28-2009, 06:59 AM | #8 | |
I like to run both of my batteries over the front axel for better weight distribution and getting the front over things. Talon | |
10-28-2009, 12:49 PM | #9 | |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
10-30-2009, 06:14 PM | #10 |
| Are you running a BEC and also, how did you wire it? In series or parallel, or some way I don't know of? lol Thanks |
11-02-2009, 11:19 AM | #11 |
Quarry Creeper Join Date: Sep 2009 Location: west sacramento
i got a cc bec on mine gunch. it's wired:in parallel off the battery +/- input on the fxr. from there to the receiver (losi mini lst2) plugs into the aux input. the servo plugs into the receivers' steering slot. man that thing is cool. it'll move rocks or my rig around no problem hitec hs-645mg oh yeah, your gonna have to unplug your battery from now on cause it'll keep power to your servo. |
11-02-2009, 11:25 AM | #12 | |
I really want to get a punk dig but I'm not sure if it will work with dual esc's. | |
11-02-2009, 11:28 AM | #13 |
dual esc would be nice for sure. my guess- would be off the front motor since it obviously stalls less.
11-02-2009, 11:32 AM | #14 |
aside from all our mods we've done, that bec thing is dramaticto the point of giggles sometimes!
11-02-2009, 11:42 AM | #15 | |
on a side note about stall, I'm thinking that when I set up the dual esc's I am going to try and program the front one with less power than the rear and see if that helps | |
11-06-2009, 09:39 PM | #16 |
Got the sidewinders, didn't feel like running dual esc's so I got a rooster crawler instead and what a difference it made, much smoother throttle control, nice drag brake and it helped with clod stall a little bit I think since I wired the motors in parallel. I didn't need to add a bec then since the rooster has a nice one built in. I tried to add the 8oz weight on my chisels and the motors simply could not keep up. Next on the list is a punk dig. This thing is starting to really impress me and I can't wait for the dig to make it a full comp rig!
