11-13-2009, 09:05 PM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Minneapolis
| Whats clod stall? No signs of it here!!!!!!
Finally found a set of motors that are the bomb! Have not had a chance to hit any tough rock situations yet, but these seem to have more than enough torque and the speed is crazy. I tried to stall the motor out by holding a tire and they shredded my output shafts immediately so now I need to get steel output shafts and cvd's. These have power! The motors are stryker 480's for planes. They are the same size as the banebots and do not require any modifications of the links to fit them. Simply move the links to the outer position just like any other bigger motors. The speed is crazy but with a good esc like my rooster crawler it can still be very precise. I am completely satisfied with the torque and don't mind the speed either. I think I might even try to find some really hard 2.2's or 1.9's and do some drifting these things are so fast. |
11-13-2009, 09:37 PM | #2 |
Quarry Creeper Join Date: Sep 2009 Location: west sacramento
now you really got me interested. so those motors broke your axles? do you think those cv's are stronger than the stock axles. i want to know if they get hot after crawling. i thought i heard someone say if you spin a fast motor slow they tend to get hot. please keep us posted. |
11-13-2009, 10:16 PM | #3 |
I wasn't able to run it long enough to find out if they get warm. Was just three wheeling and then front drive only after that. I will definitely keep you posted but it might be a week or so until I get it running again. I am going to try the steel output shafts first before I get the cvd's and see if that helps. I also think the cvd's are much stronger than stock because you eliminate that outer plastic piece that the axle goes into, so no chance of stripping that out either. |
11-14-2009, 06:58 PM | #4 |
so I didn't break the output shaft right away like I thought, just bent and twisted the sh*t out of the axle. And also it came free with all of the play that is in there. after a little bit of work on straightening the axle and putting fuel line in to absorb some of the gap, I definitely tore the output shaft to pieces Heres a couple pics: But the gears are still intact and show no signs or wear....yet :? |
11-14-2009, 07:49 PM | #5 |
Pebble Pounder Join Date: Sep 2008 Location: asheville
Cool, so how much do the motors cost? What esc where you using?
11-15-2009, 02:27 AM | #6 |
Rock Stacker Join Date: Oct 2009 Location: Jersey
Video is a must when your back up and running!
11-15-2009, 05:10 AM | #7 |
The motor sere fairly cheap. $10.99 each so not too bad and I'm running a Novak Rooster Crawler. I took a quick video of it last night with just 3-wheel drive and I'll post it later today. But I'll definitely get better video when it is back up and running hopefully by later this week. |
11-15-2009, 10:29 PM | #8 |
damn gunch, you really tore that thing up i finally made rear axles out of 3/16 alum tube- with the long servo screws cut down as the pins. she is working pretty good right now. i hope i dont bust that thing out either. i'll take running video of the rig in the next couple of days.
11-16-2009, 01:04 PM | #9 | |
11-16-2009, 02:31 PM | #10 |
sure thing gunch. im actually working on my rig right now. still messing with my links. i'll post photos later today.
11-22-2009, 06:50 PM | #11 |
So I got everything fixed last night, took 'er out for a little bit today and the batteries seem to be dying really fast or not getting a full charge :?. Anyways, I took some video that I'll post in a bit. After about 15-20 of running, the batteries were fully drained and the motors were smoking, literally . I temped them quick and the front motor was about 225 and the rear was about 190! So is it because of the slow speeds or what? Also, I had 8oz of weight in each front tire so maybe they were working too hard. The tires were getting hung up quite a bit due to the weight I believe. There was some signs of clod stall, but that is never going to be completely eliminated as the motors are wired in parallel and the power is going to go to the motor with the least resistance. I might try and wire them in series and see if that makes a difference but I really don't know what the difference is. |
11-22-2009, 08:18 PM | #12 |
Heres a video of the speed, for some reason my other video won't upload but I'm working on it Last edited by gunch; 11-22-2009 at 08:19 PM. Reason: forgot video |
11-23-2009, 11:54 AM | #13 |
gunch, your rig is sweet. that soundtrack is awesome. i love it |
11-23-2009, 01:59 PM | #14 |
^thanks, almost ready for some comps, just need a dig and I think it should do pretty well.
11-23-2009, 03:46 PM | #15 |
heres video of it crawling, don't forget the batteries were completely dead when I got to the top at the end, the motors were smoking! Last edited by gunch; 11-23-2009 at 06:25 PM. |
11-23-2009, 10:21 PM | #16 |
nice video. sick cliffclimber. she was doing it well |
11-23-2009, 10:30 PM | #17 |
also, who is the music by?
11-24-2009, 06:32 PM | #18 |
I don't know who the music is by on either of them. I click I'm feeling lucky with the box for similar length songs every time and preview until I find something different that I like. I can't even find it under my account settings. Sorry
