11-23-2009, 10:42 PM | #21 |
RCC Addict Join Date: Oct 2009 Location: Nanaimo, BC (Vancouver Island)
I want to wire the two motors up to my traxxas xl-5 and use a 7.4v lipo with about 2600mah,(actually 2 1300mah that I was going to wire in parallel) any advise on how to wire the motors and if 7.4v lipo will be ok with these 2 motors? This is new to me and I know that the xl-5 can only handle up to 9.6v, 100a forward, 60a reverse and 14a continuous, I can't wire it for 14.4 or whatever the rtr cc are set up for. Any thoughts?
11-23-2009, 10:56 PM | #22 |
Quarry Creeper Join Date: Sep 2009 Location: west sacramento
i would have to say: i think you'll be fine with the lipo on there. how to wire it? my fxr is wired in parallel (motors). is the esc made for lipo's? i dont know traxxis stuff
11-23-2009, 11:21 PM | #23 |
I have run 7.4 lipos on it with no problems, just added a lipo alarm buzzer to monitor when cells get low. hoping it will have enough torque, I'm thinking about getting the banebots and metal gears now. |
11-24-2009, 10:42 AM | #24 |
Rock Crawler Join Date: Jul 2009 Location: waterville
11-24-2009, 03:03 PM | #25 |
11-24-2009, 03:43 PM | #26 |
no problem, hope it works out for you if you decide to go this route.
11-25-2009, 07:46 AM | #27 | |
Hey gunch, any recommendations on a esc, would a rooster crawler be a better option for 2 banebots? Keep in mind that I'll have to run the motors in parallel and it will only get 7.4v lipo @ 4000mah. Thanks Quote:
11-25-2009, 10:32 AM | #28 |
Quarry Creeper Join Date: Oct 2009 Location: Minneapolis
^ a rooster crawler would suit you perfect! thats what i run and i really like it. strong drag brake, ability to have great low end control and easy one touch set-up. wow, that sounded like an advertisement.
11-25-2009, 02:30 PM | #29 |
So are you running banebots with 1 7.4v lipo and it give just as much power as the duratrax 14v dual battery setup? What size shaft does the banebots have? Will the stock pinion gears on the cc5000 work with the banebots? Thanks. |
11-25-2009, 11:51 PM | #30 |
^i use the banebots, with my stock 11 pinions haven't gone lipo yet.
11-27-2009, 12:07 PM | #31 |
Here's an update....Ordering all metal gears front and back, metal output joints, bearing kit, cvds and a set of creeper beadlocks to go with the creeper tires I already have. Bought some traxxas link ends, 1/4" brake line and 6/32 all thread rod to make new links. How well do the steering knuckles hold up on these or should I get the aluminum ones? I got an evx at a great price so that issue is solved however, I am going to run 2) 7.4v 2200mah lipos in this and need to add a lipo cutoff to it as a buzzer just wont cut it if I'm not around and and my daughter is using it. I have been searching alot on this and have come to 2 options. Option A is to get a 2s novak cutoff and wire it to the bec side of the evx however I'm adding a ubec to this so I don't now if thats an issue. Option b is to get a 4s lipo cutoff and wire it to the 14.8v set of wires from the evx, my question is which is better and why. Thanks. 49 for an artr was a great deal until I had to do all this, now I'm into it for nearly 300 bucks..........this thing better perform well lol Last edited by kurtus; 11-27-2009 at 12:09 PM. |
