03-20-2010, 04:38 PM | #1 |
Newbie Join Date: Jan 2010 Location: citrus heights
| Running one battery
I was wondering if you could run 1 battery withe stock speed controller.
03-20-2010, 10:30 PM | #2 |
Quarry Creeper Join Date: Oct 2009 Location: Florida
I know that there's enough power to run with 1 1300mA 3s lipo on a mamba micro pro... I ordered mine as the artr, so it didn't come with the stock electronics
03-21-2010, 09:11 AM | #3 |
Newbie Join Date: Jan 2010 Location: Gilbert
Jump the B1+ to the B1-. I would go to atleast a #16 wire if only using the one set of battery leads though. #20 wire will create unwanted resistance between the battery and esc.
04-08-2010, 01:29 PM | #4 |
Pebble Pounder Join Date: Aug 2008 Location: marlborough, ct
there are 4 wires for the two batteries. what happens with each wire to run one battery?
04-08-2010, 09:59 PM | #5 |
If the stock ESC operates like the EVX in my E-Maxx, then one pair is connected to the 'BEC' side, and the other is just power. You need to use the 'A' set for the single battery so that way the rest of your electronics get power as well.
04-09-2010, 05:36 AM | #6 |
b1+ b1- B2+ b2-
04-15-2010, 06:14 AM | #7 |
Connect b1+ to b1-. Use b2+ and b2- for the battery. Like I sAid before, use larger size wire. |
04-15-2010, 08:52 PM | #8 |
I'm so glad that someone has the stock ESC for a proper solution...
04-16-2010, 04:37 AM | #9 |
awesome, but i think i may have fried it already with guessing.
