03-27-2010, 05:43 PM | #1 |
Quarry Creeper Join Date: Jul 2009 Location: israel
| New links for cliffy
Hi guys.I want to make new links for my cliff climber. Can you show me how to cut the links?and what to do after?
03-28-2010, 06:45 AM | #2 |
Pebble Pounder Join Date: Aug 2008 Location: marlborough, ct
depends what you want to make them out of. some use delrin some use aluminum. some use threaded rod and put graphite tubing over the threaded rod. many ways of doing it. with alum or delrin just use hack saw and drill and tap. I don't have a cliffy yet (its on the way) but i have seen a guy here lengthen the stock links.
03-28-2010, 06:56 AM | #3 |
I want to do it like the stearing lock
03-28-2010, 08:28 AM | #4 |
Newbie Join Date: Jan 2010 Location: Gilbert
To add length to the stock links I used 1/4" alum tubing. I cut the stock link in half, drilled out the center of the cut link for 4-40 threaded rod, bored out the aluminum tubing so the ID was the same as the links OD, screwed the threaded rod into one half of the cut link, slide the aluminum tubing over the rod and link and thread the other half of the link into the other end. If you plan on bending the link, leave like an 1/8" of play where the tubing slides over the link and make the bend last. Hope this makes sense.
