Thread: Crawlmaster exact dimensions
Old 02-18-2008, 06:05 AM   #1
Default Crawlmaster exact dimensions
I would like to know a measure of the crawlMaster brushless motor (in mm please).
I'm interested in knowing the lenght of the body limited to where its diamter is bigger than one inch.
In fact from the pictures I can see that the end opposite to the pinion is very narrow and it cannot interfere
where I want to mount it, so I can neglect the lenght of that part.
Does the crawlmaster use standard pinion or the shaft is 5 mm ?
The distance between the mounting holes is the same as that of a 540 motor ?
I think to use it with a 3s Lipo and a quark 33. Is it a good setup ? and how can I program the quark 33 ?
Do I need a special usb cable as with mamba 25 ?
Thank you
Filippo
setecastronomy is offline   Reply With Quote
Old 02-18-2008, 07:32 AM   #2
I know this is unrelated to you thread but I really like your screen name. Thats one of my favorite movies.
NO MORE SECRETS
Later,Randy
racerrandy is offline   Reply With Quote
Old 02-18-2008, 09:58 AM   #3
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I will take an exact measurement when I get home, not including the backside "nipple".
A 3s lipo and quark 33 is great. You can only stick program that ESC, no computer programming is possible.
The CM mounts up like any normal 540 and has an 1/8" shaft for standard pinions.
JohnRobHolmes is offline   Reply With Quote
Old 02-18-2008, 11:19 AM   #4
The length is a hair under 32mm. I don't know when I will get Quark controllers again, they haven't imported any for quite a while now.
