02-18-2008, 08:44 PM | #1 |
Pebble Pounder Join Date: Dec 2004 Location: South Lyon
| Mamba Max & Mamba 25 problem
I have 2 MM's and 1 Mamba 25 MM 1 is in my AX-10 with a HH Crawlmaster, and everything runs perfect MM 2 is in my Asc. B44 running a 6900kV CC motor, and will not let me progranm it past the first question (as soon as I tell it which fwd/brake profile I want it exits programming mode) Mamba 25 is in my Mini-Slider running the 5400kV motor and is having the exact same programming issue as MM 2. I thought these were programmable without hooking to the computer? Is there something I'm doing wrong? |
02-18-2008, 08:55 PM | #2 |
I am having the same problem with my Mamba 25, I think we need the castle link to get it all sorted out.
02-18-2008, 09:02 PM | #3 |
I have the castle link for the MM, but I think it's b.s. that I have to buy the adapter for the Mamba 25 simply because it does not work properly out of the box...
02-18-2008, 09:04 PM | #4 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Have you contacted CC about these issues?
02-19-2008, 11:02 AM | #5 |
Quarry Creeper Join Date: May 2007 Location: Hilo
what radio are you using. i used to have that problem with my spektrum cause it took to long to connect. the esc used to boot before the radio could. when i updated the software it helped alot. try see if you could just borrow a castle link and update. my lhs did mine for me.
02-19-2008, 11:29 AM | #6 |
Try reflashing the firmware to an old version and then back again with the MM.
02-19-2008, 11:29 AM | #7 |
Rock Stacker Join Date: Feb 2008 Location: Charlotte
Yeah I've been able to program my MM25 without the Castlelink, but getting the $25 setup was worth it. Less hassle and a lot more options are available that way. But you're right, you should be able to program it with the transmitter, so give Castle a call and see what they say.
02-20-2008, 01:00 PM | #8 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
Try reversing you throttle channel... and then retry. Worked for me... Hope this helps.
