JR Racing XS3 Pro opinions? I'm looking at upgrading my POS radio and I'm intrested in the JR Racing XS3 Pro. Who has this and what have been your expierences? |
I've got the regular XS3 and about the only difference between mine and the pro, that I can tell, is the pro is silver, comes with a metal geared servo and has 10 model memory, mine has 6. Aside from that its an ok radio, lots of nice features like epa and throttle deadband adjustment for nitro. Its easy to configure and the third channel is mixable. On my super, I mix the third channel with the steering and it works pretty good that way but you CAN NOT set it up in two position mode to go left or right at the push of the button because it would stay left or right and not re-center. On my 1/5th electric bike, I mix the third channel to my brakes, to control front and rear disks and not use the esc brake. The third channel can also be used to shift a tranny like the t-maxx, its a two position channel and proportional. In the Hilift, I can use the third channel in proportional mode to hit all three gears but its dead slow so I usually set it up to hit first and third in the two position mode. An extra JR Rx will run you about $60 and I've heard that the Novak Exxtra Rx will work too, but never tried it myself. If I were to do it over, and I'm thinking about it really hard, I would probably go with the Multiplex radio listed here: http://www.rccrawler.com/forum/showp...64&postcount=1 This seems like a really cool radio system, its 7 channels, and cheap. Hope that helps, Tom |
Thanks for the info. Very informative. |
I use one for my LST2, and XX buggy. I 2nd everything metomwhou said, but will also mention that it's the Novak XXTra, and the XXL will work too, if you get the right shift and use the appropriate crystal, but it only has 2 channels. Any Airtronics FM receiver, including the synthesized version will work as well. Extra rx's can be had for cheap off eBay. I just picked up a Switch/XXtra set for $45 and could probably re-sell the Switch module to make some back. |
A follow up question. How does the third channel work? Specifically I'm looking at adding the new VF AX-10 trans mounted dig which appears to require three positions on the servo (left, center and right). |
metomwhou covered it in his post. It's either proportional, or 2 position, depending on which button it's assigned to. 3 position is not possible. Proportional would work, but it takes time to make the throw from one end to the other, and you'd have to know where center is. |
I have the JR xs3 pro. Worked great in my savage, works great in my micro rs4 (Futaba mc230cr esc) and its glitchy when used with the Novak Rooster CE. You can control the glitching if you adjust the TDB settings to about 5% on throttle and brake. My Futaba 3pm is pretty much glitch free however.. lol. Yeah the 3rd channel is 2 position. Basically its meant for shifting reverse in or out on a nitro. Right now im "fence post sitting" about upgrading to the DX3r ... :) |
If you do buy it, get some good rechargeable batts, it is power hungry.;-) |
Or, change it to 2 position mode and it becomes a simple, click up, it goes all the way one direction, click down, it goes all the way the other. That's how it's set up from the factory in the LST2 for shifting into reverse and back. |
