Servo buying... which one so i have a stock Futuba S3003 Servo and its pretty craptastic. I was looking for a stronger servo and this one seems better than the 40 oz-in my futuba has Hitec HS-645MG High-Torque 2BB Metal Gear Servo specs are as follows SPECS: Speed: 0.24 sec/60° at 4.8V 0.20 sec/60° at 6.0V Torque: 106.93 oz-in at 4.8V (7.7 kg-cm) 133.31 oz-in at 6.0V (9.6 kg-cm) Length: 1.59" (40.6mm) Width: 0.77" (19.8mm) Height: 1.48" (37.8mm) Weight: 2.11oz (60g) the price is 35.99 from towerhobbies. So is this a decent servo? |
Thats a good servo but you might as well spend the money for 5995 cause your gonna strip the brass gear in it too. |
i would get the 5645 for a little more, its a digital servo wich is better than the analog 645, it also has more tq iirc. If you go to servocity.com they have all their hitec servos on sale. cd13-except for the fact that the 5995 is about 3x as much as a 645. ive been using my 5645 through my emaxx, my nitro buggy, and now my crawler without any issues |
thanks for the info. "thumbsup" hey your local.... wheres a good place to go crawlin here in the LA area? |
I have several 2.2 rigs that have been running 645s for a long time with zero failure. I like the analog version just fine unless you have a radio that allows you to adjust the servo end points. I wouldn't use the 645 on a Super unless it was a temporary on the rear steering. I would recommend a stronger servo for a full on comp rig. I have a 5955 on mine. |
well here is the digital one mentioned http://servocity.com/html/hs-5645mg_digital_torque.html not bad but do i need the 90 degree one or a 180 degree one? i cant see me being a hardcore crawler( not yet at;east ) so im stuck on buying the 5645 or the 645s |
The 5645 has Three metal gears,brass I believe. the 5955 and 5995 are Titanium gear set.But everyone has an opinion,so say the Futaba RS403PR is the servo.Just get a good one and be done with it.Nothing worse then having a servo die in the middle of a comp."thumbsup"[ |
While i agree with your statement i think i just want it for fun for now. Competitions will have to wait. Now will someone one lead me to some rocks???? :P "thumbsup" thanks guys! |
I hear ya man,Check your region threads,Don't you guys get together out there?We meet every month to comp and a couple time to just have a good time and test :lol: |
i guess, just seems weird that im trying to make friends via teh interweb.... haha Grown ass men playing with toys.... i love it! Ill look in the regional threads. Gracias! |
I'm a chaep bast*&^ so I was on that servocity site looking. They say the 5995 is discontinued and replaced by a 5980, it's available in two versions. Steel gear and titainium gear with a $40 price differance. Looked up the price of replacement gears for the 5995, there only $8, so could you buy the steel gear servos and a set of titainium replacements for less then the whole tg version! And you would have a set of steel replacement gears when you were done! |
What are you installing it on? If it's for a super rig I say get the 5955TG. I worked my way up to it. I started with the 645MG. I felt it was too slow so I went to the 5645. I still thought it was too slow and I stripped 2 sets of gears. Now I have 2 5955TG's on my rig and have had no problems since. I even went and put one on my 2.2 rig. |
