![]() | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Carlisle
anyone else having problems with their castles bec?
![]() | #2 |
Quarry Creeper Join Date: Jan 2007 Location: Ontario, Canada
What kind of problems?
![]() | #3 |
well once I have everything hooked up and plug the battery in. my crawler will work for a second or two. then the bec fries this is now my third one and iv sent pics. of my setup to castles and they said everything is hooked up rite.
![]() | #4 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
post up pics
![]() | #5 |
![]() | #6 |
and my esc gets very hott.
![]() | #7 |
Pebble Pounder Join Date: Dec 2007 Location: Montrose
isnt the signal wire sposed to be in the 2nd pin on the radio?
![]() | #8 |
![]() | #9 |
What going on under that electrical tape?
![]() | #10 |
Tire&Foam Extraordinaire ![]() Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Have you removed the red wire from the ESC? The red wire from the ESC must be unplugged when using the BEC. |
![]() | #11 |
![]() | #12 |
does your ESC work fine without the BEC or does the ESC still get hot?
![]() | #13 |
![]() | #14 |
![]() | #15 |
| ![]() im running 8 cells and i think its shorting out the mamba 25 because it will work for those couple of seconds but once it gets hot nothing. so dose anybody think if I get a mamba max that this will fix the problem?
![]() | #16 |
![]() | #17 |
Rock Stacker Join Date: Jul 2007 Location: Wollongong Australia
What cant be seen in those pictures is how you have the little on/off switch wired up. How do you have it hooked up? could you get a picture of that also please? Frank |
![]() | #18 |
![]() | #19 | |
Official Cook of the ECC ![]() Join Date: Dec 2005 Location: Hawthorne, Florida
| ![]() Quote:
Do you have another ESC to test with? I believe the Mamba is toast. Last edited by Scattman; 03-18-2008 at 09:51 AM. | |
![]() | #20 |
I hope this is not the ESC you are trying to sell in the classified section ![]() http://www.rccrawler.com/forum/showthread.php?t=110805 Last edited by Nova's Ark; 03-18-2008 at 10:16 AM. Reason: added link |
