Thread: Having problems
Old 03-27-2008, 04:14 AM   #1
Default Having problems
I got my Sidewinder, CC BEC, and 5T puller last week. I wired everything up correctly(looked over it many times). I have a JR XS3 pro controller and JR310 receiver. My problem is all I get out of the Sidewinder when on is a blinking yellow light. Steering servo gets power but I can't turn. I tried 2 different JR controllers and 3 different JR310 recievers, none worked. Then we hooked up a Nomadio system and everything worked fine. Also tried a TQ3 and it worked w/ no problems. If I don't run the BEC w/ the JR system I get steering and throttle but when steering the throttle jumps.
I don't have a clue whats wrong. Has anyone eles experienced anything like this? Anyone have a clue what the problem is?
derwood21 is offline   Reply With Quote
Old 03-27-2008, 05:00 AM   #2
MWRCA'er
Mnster's Avatar
This sounds stupid but just weighing the obvious. Are you removing the red wire from the esc's connector pin when hooking up the BEC?
Mnster is offline   Reply With Quote
Old 03-27-2008, 05:12 AM   #3
Yes
Old 03-27-2008, 06:53 AM   #4
did you program the sidewinder for brushed motor? also did you program it to your radio? just guessing and covering the basics.
rn38 is offline   Reply With Quote
Old 03-27-2008, 06:58 AM   #5
Try reversing the throttle channel (followed by callibrating to the ESC). Did you change your deadband? If so return to "Default". I had the same problem caused by me playing with all settings that I new nothing about and didn't return to "Defaul".
Blood_Clod is offline   Reply With Quote
Old 03-27-2008, 02:50 PM   #6
yes
I tried all that too but I can't even calibrate the esc. The blinking yellow led is on as soon as I turn it on.
Old 03-31-2008, 01:55 PM   #7
did you call CC about this problem, they may have an idea, call em
jackal 69 is offline   Reply With Quote
