03-27-2008, 02:51 PM | #1 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
| Lipo wire smaller than ESC wire..problem?
Hope this isn't a noob question, but her goes. I am borrowing a TP 11.1v 3s 1320 mah Lipo from a friend but it has 18g wires to the deans and the MM I have has 13g wires to the dean's. Is this going to be a problem? I don't want to smoke my buddy's battery. I'm sure the MM will be fine though.
03-27-2008, 03:07 PM | #2 |
Rock Stacker Join Date: Jan 2008 Location: Edmonton
It totally depends on what you're using it for. You didnt say what C your battery was, but if we assume 15C, thats ~20 amps max. The Mamba Max can handle 100 amps. If you're using a small motor, it should be fine. If you have a big motor on there, I wouldn't use it.
03-27-2008, 03:47 PM | #3 |
13C/20C burst. Should be fine then right? Should I keep an eye on bat temp or is it even an issue ...55T lathe
03-27-2008, 08:45 PM | #4 |
Quarry Creeper Join Date: Oct 2004 Location: illinois
You'll have no problem with that setup, the batt will be fine.
