04-04-2008, 11:24 PM | #1 |
Rock Crawler Join Date: Apr 2007 Location: APPLE VALLEY,CALIFORNIA
| I Screwed Up My Radio Antenna
i have the dx3 radio and while doing the dig switch mod i broke the antennea wire off that little gold clip..i tried to solder the wire to the clip and i thought it worked but when i got it back together my range now is only about 25'....my question is can i just solder the wire directly to the pc board...or will i have to live with 25' range ?? thanks guys on an help or suggestions ...also ,i havent done my first comp yet ...how far is the typical range needed in a comp?? will i need more then 25' ??...thanks again Last edited by TIMZKRAWLER; 04-04-2008 at 11:27 PM. |
04-04-2008, 11:40 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
In a comp I normaly stay with in 5 feet of my rig. I would say that your safe.
04-04-2008, 11:44 PM | #3 |
Rock Crawler Join Date: Nov 2007 Location: Dayton, Ohio
I use my DX3 for my crawler and I also use it for my Rustler with a castle 4600 brushless in it so 25 feet wouldn't be good enough if he uses his for more than crawling. I would say you soldering it on should work, I dont see why that wouldn't work. If it doesn't just unsolder it and try to think of something else lol.
04-05-2008, 01:38 AM | #4 |
Rock Stacker Join Date: Dec 2007 Location: 45th Parallel
here is the replacement antenna I have used for my spectrum DX 6/7's. they are what the aircraft guys are using for the 2.4Ghz Spectrum TXs. I would hope that there is some consistency in the antennas for the DX3 & DX6/7 product lines. $9.99 + shipping http://www.horizonhobby.com/Products...rodId=EFLH1058 Flynfrog |
