01-03-2009, 10:56 AM | #61 | |
RCC Addict Join Date: Oct 2008 Location: Finland
02-15-2009, 10:06 AM | #62 |
Pebble Pounder Join Date: Apr 2008 Location: brookland
im trying determine if i fried my ccbec......when i plug it into the battery the led should come on right? i want to power my steering servo only so i only use the signal wire goin to the servo and the power wires from the bec to power it right? lol this thread is semi confusing....and im using the bec from my fxr to powter the rx and dig servo so i disregard the removal of the red wire goin to the rx am i correct.....now when i plug up my ccbec the led dont come on unless i plug the output wires coming from the bec into the rx so im guessing the power is coming from the rx side only and runnin off the esc....now that bein said that would mean in the input from the batt side isnt working .....any input would help ....im about to order another bec in just a moment but i would like some reinforcement that im right
02-16-2009, 05:36 PM | #63 |
nobody has any advice? im kinda gettin a lil frustrated with the electronics glitching so any advice at all would help
02-16-2009, 08:10 PM | #64 | |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
But, if the BEC is propoerly hooked up to the red and black battery wires on the ESC, the green light on the BEC shoulf come on when you plug in the battery. If it doesn't, it is fried and you need a new one. Based on what your are trying to do, follow this digram. I do not recommend this method if you are using a dig servo. Use Castle Creations method for powering both servos. | |
02-16-2009, 10:17 PM | #65 | |
I wanna be Dave Join Date: Oct 2006 Location: Centered
I'm running a Tekin FX-R with a 7955TG, a 45T and a Spektrum SR3500 micro Rx on 2S and 3S Lipo without dig in my 2.2 My Super has a CE Rooster, 5955TG's, V11 55's, a Spektrum SR3500 micro Rx and 2S Lipo. If I utilize this set up in both these rigs, am I in for a BBQ and some magic white smoke or a good day of crawling? | |
02-17-2009, 12:38 AM | #66 | |
02-17-2009, 07:28 AM | #67 |
if i power both my servos through the rx per castles instructions it makes my spektrum rx shut down due to voltage spikes. would you reccommend installing a power cap onto the rx to solve that problem? thats the reason i just wanted to run the steering servo with the bec.....i never had a problem runnin the dig from the rx before.....also if i split the output wires coming from the bec and run them to the servos would it take away the power from one another?
02-17-2009, 08:26 AM | #68 | |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Jon | |
02-17-2009, 09:31 AM | #69 | ||
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
Simply use a "Y" harness plud the BEC and Servo into it take the male and only plug signal to RX. Leave all else (wires) alone ,ie. ESC all three wires into RX. Last edited by cato; 02-17-2009 at 09:35 AM. | ||
02-17-2009, 01:38 PM | #70 | |
I have found CC's instructions to work best with; Mamba Max ESC or Tekin FXR (Berg), SR3100 spectrum RX, Hitec 7955TG steering servo, 5645 dig servo or Hitec micro (Berg) 11.1v 3S lipo with 13c contin. burst or a 35c burst batt (Berg). | |
02-17-2009, 03:05 PM | #71 | |
02-17-2009, 06:30 PM | #72 |
Rock Crawler Join Date: Feb 2007 Location: Simi Vly
Jesus, I am so friggin lost now. LOL.. I followed the CC instructions on back. removed the esc power wire and my 2nd servo doesn't to jack. It is set up on 3p on my DX3R. Are we supposed to just hardwire the BEC to the servo(s) now? Sorry for being a moron. I am just so in over my head it sucks ass. |
02-17-2009, 11:09 PM | #73 |
Newbie Join Date: May 2008 Location: poke town
none of the pics i have seen involve a dig servo? what would be involved in that?
02-18-2009, 07:25 AM | #74 |
02-18-2009, 07:50 AM | #75 |
I think it has more to do with the spektrum receivers, i have tried both setups on my spektrum receivers and my hitech and acoms fm receivers, never had any problems with my fm receivers but i had the spektrum receiver shut down a couple of times :?
02-18-2009, 08:05 AM | #76 |
So has anyone tried installing one of the Spektrum vlotage caps? http://www.horizonhobby.com/Products...ProdID=SPM1600 |
02-18-2009, 08:10 AM | #77 |
| $6 for a cap? i haven't tried it yet but it seems it should work, it would keep the operating voltage under spikes from the load of the servos and motor, anyone has the caps specs?
02-18-2009, 08:16 AM | #78 | |
Also if you look at the picture you can read it: 4700uf 10v | |
02-23-2009, 09:30 PM | #79 |
| could this diagram work using a Novak universal BEC? I'm fustrated right now because I tried to use the wiring diagram in the crawler edition of RC Driver and it doesn't work. I have a JR 9100 steering sevo and a JR mini225 for the dig. I have a HH brushed torquemaster, a Tekin FX-r ESC and a Spektrum Rx. I'm using a 3s LiPo for juice. The Novak directions completely contradict the wiring diagram on the RC Crawler edition, and the diagram on here that I included is also different. The Novak BEC doesn't have a signal wire on the output, just a black and red wire that had a plug that was removed from trying to wire it the way the magazine article showed. Thanks for any help. I've tried to help myself by searching, but I'm in over my head a bit so I'll swallow my pride and do the smart thing- ask for help! |
02-24-2009, 05:16 AM | #80 | |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
