11-12-2009, 02:17 AM | #121 |
Newbie Join Date: May 2008 Location: Bali... Bali... Bali...
I just change my wiring diagram, i run mamba max esc, cc bec, DX3R, one steering servo, one dig servo and 3 cell lipo on my MOA. After i trying this wiring diagram my servo lost its speed, it becomes slow, then i try to change my frame rate, but that not helping. I run my signal cable from the servo to my receiver while the neg.positif wire goes straight to cc bec. I'm wondering what did i do wrong, could someone tell me why i have this problem. |
11-25-2009, 11:58 PM | #122 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| my two bec diagrams
my two bec diagrams the top one is a direct wire to the servo the bottom one is using a y-harness |
11-26-2009, 10:04 AM | #123 |
RCC Addict Join Date: Feb 2006 Location: ccxc
if done as above i would leave out my dig servo........is that bad?
11-26-2009, 10:17 AM | #124 |
just plug into the Rx as normal if its a servo operated dig switch or electronic dig,,if it's a servo driven mechanical dig like a dna or vp hurst then wire the dig servo just like the steering servo shown in the diagrams above
11-26-2009, 10:40 AM | #125 |
ok...i liked the y harness idea but i guess thats a no go with 2 servos
11-29-2009, 10:17 PM | #126 |
what are the two servos being used for,,,dig,,steering,,?
11-30-2009, 08:52 PM | #127 |
Rock Stacker Join Date: Nov 2009 Location: seattle
It think the reason to run the servo directly of the BEC is so you can run max voltage to a high torque servo while running lower voltage to the RX and dig servo.
11-30-2009, 08:55 PM | #128 |
11-30-2009, 09:02 PM | #129 |
02-09-2010, 11:39 PM | #130 | |
Rock Stacker Join Date: Nov 2009 Location: Hawaii
Used the 'search' and found this thread. Very informative, but a little confusing. Have a Novak Rooster with a 55t motor, spektrum reciever, hitec 7954 steering servo, and the factory Venom dig servo for dig. And I also run a 7-cell nihm pack. The radio is a DX3s and using the 3 channel sport reciever. I was planning on getting a cc bec and program it to 7.4 volts to run the 7954 and bypass the internal 6 volt bec in the rooster. So I would use the first diagram where the bec is coming off of the battery wires and only feeding the 7954, and have only the signal wire from the 7954 going to the reciever? Also would it matter if the wires going from the bec to the battery is hooked up on the esc side of the plug, so I can use different batteries? Thanks for any help! Last edited by HwnElf; 02-09-2010 at 11:47 PM. Reason: info added | |
02-10-2010, 04:29 AM | #131 |
Rock Stacker Join Date: Aug 2008 Location: tamworth, nsw, australia
how're yez... i also confused.....sort of.....i think. I've gone all out and bought one of those really expensive BEC's from Hong Kong, you know, the ones that have really well written and layed out instructions....... I have a TEKIN fx-r in an AX-10 with a 1250mah 3s 20c pack powering a 75t and 2 X mg996 servos. My original intent was to have the front servo's power boosted with the external BEC and leave the rear servo powered by the fx-r internal BEC........but thinking about it today, I'm now wondering if this is gunna be possible..... Looking at all the diagrams and what-not has me at a loss as how to wire this puppy.....any suggestions appreciated...... |
03-28-2010, 11:40 AM | #132 |
Newbie Join Date: Jun 2007 Location: Bandung
any body have any diagrams for Berg using BEC,2 receiver, 1 servo, and 4PK radio?
07-29-2010, 10:34 AM | #133 |
Quarry Creeper Join Date: Sep 2007 Location: Near my tools
want to make sure if I can run the BEC like this?any miss wired on my diagram? |
07-29-2010, 10:41 AM | #134 |
Rock Crawler Join Date: Jul 2009 Location: boise
why two batterys? thats the point of the BEC to eliminate the second battery.
07-29-2010, 06:46 PM | #135 |
I'm thinking about saving the 1st battery, so it would power the esc 100%.
07-29-2010, 07:03 PM | #136 |
Ive actually thought of the same thing but using like a real small 850mah lipo
08-11-2010, 11:12 PM | #137 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
Here is pretty clear wiring diagram I did for mine this morning. This setup assumes you will run the dig servo straight from the AUX port. |
08-22-2010, 03:59 PM | #138 |
Newbie Join Date: Apr 2008 Location: milford
| bind plug on dx3e
I was wondering if you can plug a ccbec into the bind port on the receiver ?I'm running two servos one for steering and the other for a dig will this work ok
12-27-2010, 06:12 PM | #139 |
Quarry Creeper Join Date: Dec 2010 Location: Princeton Mass
My wire job for a LCC using a hs65mg 6v dig servo and a hs7950 7.4v steering servo. I used the ccbec 10amp set to 7.4v and the castle mamba max pro esc set to 6v. I used a servo wye adapter and connected the ccbec in one end and the hs7950 in the other end. I then pluged the adapter into the steering port on the futaba rx after i removed the red wire. I pluged the mmp esc bec into the throttle port. I put my dig servo on channel 3 with the rx and set up in my futaba 4pl. It all works so far. Sorry my pics are a little crappy from my iphone. I need to finsh the motor install and hope all is well. Lots of reading but it helped me out alot thanks Gerry Here is a link to my pics in another thread thanks Wireing setup |
01-27-2011, 09:19 AM | #140 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
so getting ready to wire up my scx10 build. below is a diagram i have drawn up. any feedback appreciated. I know my bec isn't running servo because br-xl should be able to handle it. I am no noob but figured I would post up this for opinions and thought it may help someone else out as well |
