05-31-2011, 09:47 AM | #141 |
Rock Crawler Join Date: May 2010 Location: Albuquerque
so after reading through this entire thread all it is, is bec wiring options . . . . here is a task for you wiring nuts . . . . can someone post a definitive wiring diagram for wiring duel fxr's with 2 motors, a sr3000 rx with ccbec?
06-03-2011, 08:24 PM | #142 |
Newbie Join Date: May 2011 Location: prejudistville
I believe that it works but what you want to do is route all the current through the BEC, and what you have is just the red wire from the BEC to the servo so the current will still flow back through the black wire to the receiver. I believe the black wire should be coming from the BEC.
07-20-2011, 11:23 AM | #143 |
Quarry Creeper Join Date: Feb 2011 Location: Lynnwood
I have read through this thread an i am a little confused now. What is the correct way of connecting the BEC directly to the Servo? OR |
07-24-2011, 01:50 PM | #144 | |
Newbie Join Date: Jun 2011 Location: texas
I used this diagram to wire up my Moa crawler with single fxr,punk dig,duel 45t motors and Castle bec. I tried to understand what is going on but could only grasp 95 percent of whats happening. What is purpose of the red wire being isolated off of the fxr? Is one of the bec wires supposed to be isolated like some say in other diagrams? I know the default CC bec output is like 5 volts or something. If i am happy with speed of the futaba S9157 steering servo i am using there is no need to change output of the Bec Right? I found this diagram very useful but had to search a lot. I wish this forum would sticky some diagrams for typical set ups. | |
07-24-2011, 03:02 PM | #145 | |
Frankly, I run the BEC output direct to the servo and leave the ESC BEC to power the RX. Either way works. | |
07-24-2011, 11:12 PM | #146 | |
07-25-2011, 01:19 AM | #147 | |
Newbie Join Date: Jul 2011 Location: Juneau
The way I see it is that you are just connecting the + and - on both esc, wiring to each motor and just choose on esc on where to place the steering servo. | |
09-26-2011, 01:59 AM | #148 |
Rock Crawler Join Date: Jan 2011 Location: Okanagan
so some people say that connecting the black wire from the BEC to the receiver with the signal wire (when the BEC is only powering the servo) will stop glitches, but others say it runs 100% fine with only running the signal wire from the servo to the receiver. anyone have any input on this? *edit* I dont think you need it at all and would not affect anything would it? so does this seem right? and cover all or most? Last edited by Spiike; 09-26-2011 at 05:27 AM. Reason: made my own diagram |
09-26-2011, 06:56 AM | #149 | |
Try it one way yourself, switch if need be. My son & I run Futaba's ( me = 3PM-x, he = 4PL) with the CC 10A BEC red & black direct to the servo with no radio glitching. YMMV | |
10-03-2011, 02:03 AM | #150 |
well so far so good, my receiver isn't lacking power like it did before, the 3A off my novak ESC runs the receiver and not very often do i full throttle at far distances with my ol' 27mhz ax1/ar1 combo, if i do turn to lipo and/or change the bec to higher voltage im ok, and not need to worry about the rx receiving higher voltage than it should. I did leave the black wire connected, and only removed the red wire to the receiver from the bec.
10-19-2011, 03:32 PM | #151 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Okay guys and gals, i have a request. I am getting ready to wire up my super bully, i have 2- tekin fxr's, 2- 7980 hitech servo's, 2- castle bec's and futaba r2104gf reciever all run off 3s lipo. My question is does anyone have a diagram for this setup? |
10-19-2011, 04:01 PM | #152 |
| the diagram i made supports your setup, except only running 1 servo per castle BEC. add another ESC and splitting the deans 2 more times to accomidate the extra BEC and ESC. remove the winch (which was optional anyways) no dig? then a Y harness for both ESC to wire into the throttle would also finish the wiring off. but if you use dig, esc wires to the dig and the throttle and the dig switch wires would go to the receiver of course.
10-24-2011, 09:37 AM | #153 | |
got it all figured out and running, easier than i thought. | |
10-24-2011, 02:42 PM | #154 |
| yeah its pretty easy once you understand it all. i also read that the CC BEC's wire only supports 5A. so if you have 2x 3A servo on 1 cc BEC, the positive wire needs to be upgraded, and little JST connectors don't support that much amps neither. so limiting the CCBEC to 1 servo and 1 small servo, and running the other high power/high torque servo on another CC BEC. or i heard that replacing the power wire to a higher gauge works too.
10-24-2011, 02:47 PM | #155 | |
i've got seperate cc bec's on each 7980 set to 7.3 volts and they turn my 8" rover / moabs very easy. | |
10-24-2011, 03:15 PM | #156 | |
just doing a basic distance test in a field, i get an extra 20-30 feet when the ESC's BEC was wired to the receiver vs the BEC running servo and receiver. other electronics may vary, this was tested with the Novak Super rooster with a 3A internal BEC. using an RC4WD 35T motor, a HS-645mg (ccbec set @ default), AX-1 AR-1 27mhz 2ch rx+tx, with winch and lights receiving own power from hijack deans. | |
11-06-2011, 10:58 AM | #157 |
I THOUGHT I'DE SHARE MY DIAGRAM FOR MY SUPER. EVERYONE DOES SOMETHING A LITTLE DIFFERANT AND THIS IS WHAT I CAME UP WITH AFTER MUCH RESEARCH AND COMPARISON'S. |
11-06-2011, 11:08 AM | #158 |
| Ummm......the yellow signal wires go from the 2 servos to the RX, NOT from the 2 BEC's. Last edited by Charlie-III; 11-06-2011 at 05:16 PM. Reason: Deleted drawing, it's been updated and no longer visible. |
11-06-2011, 04:19 PM | #159 | |
CORRECT,MY MISTAKE IN DRAWING IT ,ALSO WITH THE GROUND WIRE TOO. HERE IS A EDITED DRAWING. Last edited by CREEPERBOB; 11-06-2011 at 04:23 PM. | |
11-06-2011, 05:14 PM | #160 | |
Now, should I be really picky and say that the "ground" (black or brown wire) is normally towards the outside edge of the RX?? Last edited by Charlie-III; 11-06-2011 at 05:42 PM. Reason: change "red" to "brown"....duhhhhh | |
