09-12-2018, 10:56 PM | #1 |
Rock Crawler Join Date: Dec 2013 Location: Tuxedo NY
| Castle BEC 2.0 dual wire, 4ws, 2 servos, Holmes bypass???
I just got the 2.0 bec since the old one seemed not quite up to the job on my 4ws bomber. I’m running a 2290 and a 7950, front and rear. I had been using the Holmes double bypass adapter. The new bec has 2 output wires. Can I use a splitter / joiner wire to connect the 2 outputs of the BEC together, and just run that to the existing double bypass setup? Or should I route one to each servo with their own regular bypass? Some other setup? |
09-13-2018, 12:04 AM | #2 | |
Rock Stacker Join Date: Aug 2018 Location: Orlando
| Re: Castle BEC 2.0 dual wire, 4ws, 2 servos, Holmes bypass??? Quote:
Sent from my SM-G965U using Tapatalk | |
09-13-2018, 05:57 AM | #3 | |
Use one power lead from the bec per servo. The new servo has twice the output , but small leads that could not pass enough current. Hang up and Drive | |
09-14-2018, 09:02 PM | #4 |
Thanks y’all!! I’ll give it a go!! I do love the 4ws, it helps in many ways for sure!! |
Castle BEC 2.0 dual wire, 4ws, 2 servos, Holmes bypass??? - Similar Threads | ||||
BEC and 4ws dual servos, intermittent power | chalmene | Electronics | 14 | 08-28-2016 03:10 PM |
Holmes RX Bypass and CC BEC soldering require? | Banjoblue | Axial Wraith | 10 | 06-19-2015 10:23 AM |
Castle BEC, Holmes RX bypass not working | MIcrawler | Electronics | 4 | 01-07-2015 06:51 PM |
how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)? | ussprinceton2004 | Axial Wraith | 23 | 01-29-2012 08:24 PM |
