Thread: Tower Pro MG945 vs. MG946R
Old 04-28-2008, 01:22 PM   #1
Question Tower Pro MG945 vs. MG946R
I see that TP has introduced a new servo (MG946R) to replace the MG945.
Anybody had a chance to make an actual comparison between the two? I've been running the 945 since last summer and while they are strong, they do have their quarks. I just ordered two more 945's for 16.00 (a set) because at the time 946's were hard to come by. (26.00 including shipping is worth risk for two servos with this much power)
In the meantime I am wondering if the claim made by TP that the 946 is an improvment over the 945 is a valid salespitch.
Sean
SeanD is offline   Reply With Quote
Old 04-28-2008, 02:22 PM   #2
Scattman's Avatar
I have a few 945's and 995's. I recently picked up a 946R and with less than 10 minutes on it, it locked up. I had epa's set and running 6.2 volts through a Castle BEC. No issues from my other TP servos. I hope I just got a bad one.
In the 10 minutes it worked, it seemed better than the 945.
Scattman is offline   Reply With Quote
Old 04-28-2008, 03:08 PM   #3
~The Scale Shop~
STANG KILLA SS's Avatar
the new circuit board is supposed to eliminate all the jitters.
STANG KILLA SS is offline   Reply With Quote
Old 04-28-2008, 03:17 PM   #4
Scattman's Avatar
It was definately less jittery........................................... .....until it stopped working. Now it has no jittering problem at all.
Old 04-29-2008, 12:03 AM   #5
My lhs said it was slightly stronger and faster.
mysharona is offline   Reply With Quote
Old 04-29-2008, 12:43 AM   #6
The board was updated to be better for Planes. So it should have less jitters. Also has 1 or 2kg more torque at 6v...
run2jeepn is online now   Reply With Quote
Old 04-29-2008, 12:54 AM   #7
I just ordered a bunch of both the 945 and the newer 946R Ive been running a few for awhile without issue and they are definitely a little stronger.
rockwerks is offline   Reply With Quote
Old 04-29-2008, 02:40 PM   #8
Gavyn is my BFFL
Nabil's Avatar
i run my 946 at 7.4 v with no problems
Nabil is offline   Reply With Quote
Old 04-29-2008, 03:17 PM   #9
On any of the tower pro servos the EPA's set correctly is paramount importance. IVe only had 3 fail on the 100 or so Ive sold and each time the gears came off of the shaft splines because of them constantly being forced into a bind position. The "R" units are less forgiving the the standard versions
Old 08-04-2008, 05:17 AM   #10
newbie8324's Avatar
i have been having issues with both of my tp mg945. one just wont turn and the other one turns but comes back to center with out me releasing the steering knob, and wont do as i ask when i try to engage the steering trim. anyone else have this problem???
newbie8324 is offline   Reply With Quote
