Thread: servo trouble
Old 04-28-2008, 10:09 PM   #1
Default servo trouble
when i first hooked upmy steering servo it turnes all the way to the right, i used my trim to correct it. since then i lost that remote and now on my new one my servo seems sluggish turning to the right,i cant figure out the problem? what would an external bec do?
sw2jeeper is offline   Reply With Quote
Old 04-28-2008, 11:05 PM   #2
did you center the servo before you put the arm on?
mysharona is offline   Reply With Quote
Old 04-29-2008, 08:18 AM   #3
Take off the servo horn, turn on the ESC and your transmitter, center the trim for steering on the transmitter, replace the servo horn with the wheels as straight as possible... How does it work now?
Cake Eater is offline   Reply With Quote
Old 04-29-2008, 08:31 AM   #4
Also make sure your sincing your transmitter and rec. You will not get proper settings if you dont!
crawlbe4youwalk is offline   Reply With Quote
Old 04-30-2008, 08:18 PM   #5
what is sincing? I have had many rc cars and never heard of that, this is why the problem is so puzzling to me. Ive never experienced this.
