| | #1 |
| Newbie Join Date: Mar 2006 Location: Santa Rosa
| hey guys, i just got my ax10 built and running last night and after setting up the esc everything seemed to be working perfect until i tried to use reverse. When in reverse i pretty much have no power and the thing barely moves.Any ideas on what the problem could be? |
| Sponsored Links | |
| | #2 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| Have you programmed it for 100% reverse throttle and set your throttle endpoints? |
| | #3 |
| I just did the quick start programming. |
| | #4 |
| I just calibrated the esc to set the endpoints and its still super slow. Guess i'll just have to wait a few more days for my castle link to get here. |
| | #5 |
| yep. Stock is 30% reverse I think. |
| | #6 |
| Quarry Creeper Join Date: Oct 2005 Location: ELLENSBURG, WA
| you can call castle toll free and tech will walk you thru the manual reverse setup real quick. It's a lil vague in the book as to the beep sequence. then you'll have it until you get the link. |
| | #7 | |
Is the castle link easy to use, the interface makes it appear so but i have never used it? | |
| | #8 |
| I'm Dracula, Bitch. ![]() Join Date: Sep 2005 Location: Houston, TX
| | #9 |
| Rock Stacker Join Date: Mar 2008 Location: Tulsa
| the cc program is very simple to use. |
| | #10 |
| Rock Crawler Join Date: May 2007 Location: lacey
| also make sure that the brake on the transmitter is set to 100%, found out after running around that my thumb was hitting the brake adjust on my dx3r and turning it down. sometimes I had reverse, sometimes not much :-P. |
| Thread Tools | |
| Display Modes | |
